400 TH trans mount
Old September 24th, 2015, 08:55 AM
The Bug Man's Avatar
400 TH trans mount
Noticed a high speed vibration in floor board behind drivers seat. Nothing spectacular but noticeable. Checked bushing in trans mount on cross member and sure enough compressed and beat up. Was going to replace with original type but am looking at the after market poly units also. Are they that much better than original type ?
The Bug Man is offline
Old September 24th, 2015, 10:05 AM
Lt. Buzzkill (ret.)
copper128's Avatar
I imagine the used-up one is original to the car. An aftermarket stock replacement rubber trans mount probably won't last as long as OEM, but it'll do the job. I don't see any advantage to the poly units in a typical street driving environment.
copper128 is offline
Old September 24th, 2015, 01:47 PM
lemoldsnut's Avatar
Check your u joints too while you are under there.
lemoldsnut is offline
Old September 26th, 2015, 12:55 PM
jfb
jfb's Avatar
I have a polyurethane mount and have had zero problems. The material itself is just better from what i have observed. There are also cushions on the end of the trans cross mount ,by the frame ends.that break down and can cause some vibration check them also.
jfb is offline
Old September 26th, 2015, 07:35 PM
Rattlecan's Avatar
2nd on checking the driveshaft, too
Mine had a slight vibration at certain speed, 65mph or so.
When I had the TH400 rebuilt I installed new tranny mount as the old one was oil soaked. I also had the driveshaft "rebuilt" with new spicers and a high-speed balance. That driveshaft work was about $150.
Now no more vibration, and I've gone slightly more than 65.
Rattlecan is offline
Old September 28th, 2015, 08:56 AM
Thanks guys . Decided to stay with OEM type. All is fine now.
Octania
August 26th, 2015 06:49 PM
Oldracerjones
February 1st, 2014 06:05 PM
busman442
November 16th, 2013 03:20 AM
gearheads78
August 13th, 2012 07:25 AM
1k442
March 3rd, 2010 08:03 AM
Quick Reply: 400 TH trans mount
