Oldsmobile needs help pls read
Old April 6th, 2015, 08:55 PM
606kentuckyboy's Avatar
I have a 87 olds all Original 42 k 7a heads. Took it on interstate and over heated. Now it leaks coolant out the exhaust and looses compression after heated up. No water in oil. I'm looking to buy a rebuilt 350 and use my old parts to finish the build. Would this work and if so any suggestions? Please help
606kentuckyboy is offline
Old April 7th, 2015, 03:12 AM
Oldsdruid
rocketraider's Avatar
If it's currently an Olds 307, an Oldsmobile 350 (or 330 or 403) engine it will be a drop-in as the 307 and 350 blocks are externally identical. All the accessories will bolt on too.
Just make sure your transmission can handle the extra engine. A later 200-4R should be OK if you're not romping on it all the time but it will be the weak link in transplanting a larger engine.
Now, if you're thinking Chevrolet 350, that opens a whole new can of worms. It will work, but not as simple or easy as an Olds engine.
rocketraider is offline
The_German
July 14th, 2011 02:10 PM
The_German
May 15th, 2011 02:02 PM
sx455raidercelticfan
October 8th, 2010 03:22 AM
lene
April 6th, 2010 04:34 PM
southcarolina803
July 2nd, 2008 07:14 AM
Quick Reply: Oldsmobile needs help pls read
