69 Cutlass: correct decals locations?
Hi guys!!
Before posting this thread, I tried to find some good pics on Google and tried with the "search" function, but did not found what I've been looking for!
I'm restoring my 69 Cutlass Supreme, and would like to add the decals that came with the car back in 1969!
So I'm looking for tips, pics... that could help me with the correct decals factory locations, and also which decals.
Mainly looking for engine bay, air filter, trunk, door jamb decals locations...
Thanks a lot for your help!!
Sorry, forgot to mention that I looked at the 1969 Assembly Manual.
But did not find all the infos I needed.
(No info about Emission decal on the radiator plate, the Air Cleaner decal "Keep your GM Car all GM", tire pressure decal...)
Thanks Dean for your help!
For the moment, do not have them as I wait for tips to order the good ones.
Would need infos for:
-"GM Mark of Excellence" Door Decal
-Tire Pressure Decal (door jamb)
-"Keep your GM car All GM" Air filter Decal
(Seen some stickers that were in the middle of the air cleaner, some that were a little bit on the side...)
-GM Anti-Freeze Coolant Protection Decal
-Emission & Tune-up Decal OU 1969 350 4 Barrel
-Jack Instructions Decal
-Jack Stowage Decal for Specialty Wheel only
(As I have a SSI wheel in my trunk, guess I would need this one?)
-Jack Assembly Caution Decal
-Anti-Spin Differential Trunk Lid Decal
actually it's on the drivers door (the shell above the latch area), not the door jamb.
make sure you have the correct coded one for your app. not every one was a 1971 NJ code that lots of resto houses sell. Somewhere on the side of the air clearer housing. while the manual shows the location, the worker putting the decal on didn't exactly get out a tape measure and make sure it was exact per the manual
Almost every one of those decals is in the Assembly Manual. For the ones that aren't, Mark Cornea (Dr. Decal) provides a free service to show and tell where they need to be placed.
