69 Cutlass: correct decals locations?
Old Jan 22, 2015 | 03:44 PM
Christophe2m6's Avatar
Question 69 Cutlass: correct decals locations?
Hi guys!!
Before posting this thread, I tried to find some good pics on Google and tried with the "search" function, but did not found what I've been looking for!
I'm restoring my 69 Cutlass Supreme, and would like to add the decals that came with the car back in 1969!
So I'm looking for tips, pics... that could help me with the correct decals factory locations, and also which decals.
Mainly looking for engine bay, air filter, trunk, door jamb decals locations...
Thanks a lot for your help!!
Old Jan 22, 2015 | 05:39 PM
dnmfranco's Avatar
Chris do you have the stickers already or do you need to get them.
If you didn't I can tell what stickers you will need and where to place
Dean
Old Jan 22, 2015 | 09:58 PM
The assembly manual will have what you
Old Jan 23, 2015 | 01:47 AM
Sorry, forgot to mention that I looked at the 1969 Assembly Manual.
But did not find all the infos I needed.
(No info about Emission decal on the radiator plate, the Air Cleaner decal "Keep your GM Car all GM", tire pressure decal...)
Dean
Thanks Dean for your help!
For the moment, do not have them as I wait for tips to order the good ones.
Would need infos for:
-"GM Mark of Excellence" Door Decal
-Tire Pressure Decal (door jamb)
-"Keep your GM car All GM" Air filter Decal
(Seen some stickers that were in the middle of the air cleaner, some that were a little bit on the side...)
-GM Anti-Freeze Coolant Protection Decal
-Emission & Tune-up Decal OU 1969 350 4 Barrel
-Jack Instructions Decal
-Jack Stowage Decal for Specialty Wheel only
(As I have a SSI wheel in my trunk, guess I would need this one?)
-Jack Assembly Caution Decal
-Anti-Spin Differential Trunk Lid Decal
Old Jan 23, 2015 | 07:41 AM
junior supercar's Avatar
those are in there. you must have a poor and incomplete copy of the assembly manual.
not used in 69 as my two original paint cars don't have them. But they do go right next to the below tire pressure decal
actually it's on the drivers door (the shell above the latch area), not the door jamb.
make sure you have the correct coded one for your app. not every one was a 1971 NJ code that lots of resto houses sell. Somewhere on the side of the air clearer housing. while the manual shows the location, the worker putting the decal on didn't exactly get out a tape measure and make sure it was exact per the manual
Old Jan 23, 2015 | 10:17 AM
dnmfranco's Avatar
Chris if you pm me your address can send you pics where they go
Old Jan 23, 2015 | 10:24 AM
Thanks a lot junior supercar!!
Done!!
Old Jan 23, 2015 | 10:34 AM
dnmfranco's Avatar
Chris pics sent hope it helps
Dean
Old Jan 23, 2015 | 01:53 PM
Dean
You rock!!!!
Old Feb 6, 2015 | 09:17 AM
Hi guys!!
Found this link that may help a lot!!
1969 Oldsmobile 442 Cutlass Details
Old Feb 6, 2015 | 10:05 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Fusick sells the stickers
Old Feb 6, 2015 | 10:09 AM
Almost every one of those decals is in the Assembly Manual. For the ones that aren't, Mark Cornea (Dr. Decal) provides a free service to show and tell where they need to be placed.
Old Feb 6, 2015 | 10:10 AM
Yes!!
And already on the way to my home!!
Old Feb 6, 2015 | 10:15 AM
Nicely done sir, Post some pictures. A tip...use google to search your subject. It almost always will lead you back here to the correct thread(s).
2blu442
Nov 13, 2017 12:18 PM
Gunfreak25
Dec 24, 2010 09:49 PM
4speedBench
Apr 17, 2010 05:08 PM
johnyyy
Feb 7, 2009 08:23 PM
1BAD68"S"
Aug 20, 2006 08:06 PM
