67 Turnpike Cruiser Conv Ebay
Old Oct 29, 2014 | 08:21 AM
Oldsmaniac's Avatar
http://www.ebay.com/itm/Oldsmobile-C...s#ht_214wt_886
Wow must have been a looker back in the day, too bad the frame is rotted. Hope someone saves it! It is a very rare optioned car.
Old Oct 29, 2014 | 08:37 AM
steverw's Avatar
Those rivits on the VIN tag dont look right to me. Shouldnt they be the rosette style rivits? Left one looks to not be flush to the tag.
Old Oct 29, 2014 | 08:42 AM
Oldsmaniac's Avatar
The rivets look ok to me. The ones on the trim tag will look different.
Old Oct 29, 2014 | 08:53 AM
It's rare, but not necessarily desirable. If the body can be saved, it would be something
to restore and upgrade the 2 barrel and cam to some 442 spec stuff. Then you could have a numbers matching Cutlass that would keep up with a 442.
If they ever repop the 66 OAI cleaner, it would be something to see a 67 TC car with a modded 66 repop cleaner with just the middle 2 barrel hole.
Old Oct 29, 2014 | 11:58 AM
lemoldsnut's Avatar
If someone buys it I have a good frame
Old Oct 29, 2014 | 07:46 PM
66-3X2 442's Avatar
Are you sure about them? They are not the rosette style like on other 67's.
Old Oct 29, 2014 | 07:51 PM
steverw's Avatar
Thats what im saying, Im certainly no authority and dont know when it started but i have seen and read that only rosette style rivits were used and that they are not available and illegal to make, sell or obtain in any way. Again Im no authority on the subject. Maybe it is the original VIN for the car, someone could have removed it to paint it then pop rivited it back on, who knows what may have been done years ago. But they look like pop rivits to me.
Old Oct 29, 2014 | 08:18 PM
Lonestar's Avatar
Still on the planet...
What about the "67" in the VIN tag, does it look legit?
Also curious about "re-framing" the car after all of the discussion on a prior thread about a re-body?
Old Oct 30, 2014 | 05:50 AM
Oldsmaniac's Avatar
They look like the ones on my 67's here is a pict. maybe some plants used a different style. Here is a pict
Old Oct 30, 2014 | 06:38 AM
66-3X2 442's Avatar
Unless I'm just plain goofy,yours are the rosette rivets and the eBay units are not.
Old Oct 30, 2014 | 06:40 AM
66-3X2 442's Avatar
That's just further proof that factory stamped #'s are not perfect. The frame is just another part and was meant to be a serviceable part just like a body shell or any other part.
Old Oct 30, 2014 | 06:41 AM
Oldsmaniac's Avatar
I still say they look the same but thats just me as well.
Old Oct 30, 2014 | 04:18 PM
67442nut's Avatar
Never saw a Turnpike Cruiser Convertible before.
Must be pretty rare. Power windows and power antenna, too.
If I weren't already "overloaded", I'd be tempted to go for this one.
Those rivets DO look suspicious.
I've only seen the "rosette" type rivets on '67's.
If the engine has matching numbers, the tag is probably legit.
It looks right.
At least I know some of the characters are misaligned on the tags on my cars.
You guys got my curiousity up.
I have a '67 4-4-2 convertible, a '67 CS convertible and a '67 post coupe here at the house.
I just went out and verified what's on them.
They all have the rosette type rivets.
I didn't check which plant they came from.
I have 2 other '67's at another location.
I'll check them tomorrow.
Old Oct 30, 2014 | 04:37 PM
67442nut's Avatar
If the frame is very rusty, the numbers probably aren't legible anyhow.
Old Oct 30, 2014 | 04:53 PM
67442nut's Avatar
I think it would be more rare and desirable as an original T.P. Cruiser convertible
with the correct Climatic Combustion Control System and air cleaner than to be modified into a 4-4-2 engine.
I believe the T.P. Cruiser engine was designed more for fuel economy.
Old Oct 30, 2014 | 04:54 PM
lemoldsnut's Avatar
If someone decides to buy it I have a good frame.
Old Oct 30, 2014 | 07:54 PM
steverw's Avatar
Oldsmaniac your rivits are definately the rosette type, the edges are scalloped
Old Oct 30, 2014 | 08:07 PM
66-3X2 442's Avatar
Ed
I was referring to the odd vin tag stamping.
Old Oct 30, 2014 | 09:36 PM
67442nut's Avatar
Ed
Right.
I was just confirming your comment by mentioning the same type of misalignment
of the characters on the VIN tags on my cars.
geowindow6768
Jun 21, 2015 03:34 PM
Dave Siltman
Aug 27, 2011 09:47 PM
ithaca4me
Oct 18, 2010 04:34 PM
rcorrigan5
Aug 10, 2009 07:33 AM
