edelbrock air gap intake manafold
IM in the middle of swapping the 350 for a 455 in my 1970 olds cutlass. The engine is still with the builder and he recommends a air gap manifold. Does anyone know if my hood will close with this type of manifold? I don't have a 455 intake to measure but Edelbrock says the height is 5.50 inches. I also need to think about a radiator, should I go 3 or 4 core and what will fit.
Thanks, Mike
Thanks, Mike
If you don't have a Ram Air Hood, then this will work. It is not compatible with a Edelbrock or Carter carb with electric choke. It will work with any standard Holley or Rochester 4v.
http://www.ss396.com/chevelle/ATE-3907.html
Last edited by oldcutlass; Mar 29, 2014 at 01:25 PM. Reason: added link to the air cleaner forgotten
