stock 307
Old May 23, 2008 | 08:00 AM
87cutlas's Avatar
stock so far
stock 307
i have been doing some research on the 307 oldsmobiles that came in the g bodies and i have modified mine to be near the equivalent of the h. 0. and i was wondering how much horsepower the base 307's and the h. o. 307's came with?
just wonderin
Old May 23, 2008 | 08:18 AM
Lady72nRob71's Avatar
The base 307 (VIN Y)put out a whopping 140hp and the HO put out 180hp.
The HO (VIN 9) had a different cam, EEPROM with different timing curves, duals, and I think the heads were different.
Old May 27, 2008 | 06:49 PM
87cutlas's Avatar
stock so far
thank you lady
Old May 27, 2008 | 07:04 PM
I'll add that 140 HP for a VIN Y motor is probably being generous. Sad but true...
Old May 27, 2008 | 07:13 PM
Redog's Avatar
The 307 Y motor in a Delta 88 ran an impressive 20.66 @ 64.66 MPH in the 1/4 mile
Of that 140, 90 goes to the wheels
Old May 28, 2008 | 12:38 AM
88 coupe's Avatar
Junior Member
Originally Posted by Lady72nRob71
........ duals ........
Dual outlets? Were duals ever offered on a 307?
Norm
Old May 28, 2008 | 05:25 AM
Yep, the VIN 9 engines came with dual outlet exhaust from the factory. While not a true dual setup, the Y pipe was bolted behind the cat converter. It had dual mufflers and resonators and one cat.
It was standard on the 442 and H/O in the mid 80's.
Old May 28, 2008 | 10:13 AM
Yes, but unfortunately that system still used the somewhat restrictive crossover under the oil pan and single pipe running from the RH exhaust manifold to the converter.
Old May 28, 2008 | 03:12 PM
Too bad the high performance motor for Olds during the 80s sucked so much. It would have been cool if Olds made an awsome car like the Buick GN in the 80s. I guess the 442 was OK, but it was definitely more show than go. I think I like 84 the best.
Old May 28, 2008 | 11:14 PM
88 coupe's Avatar
Junior Member
........ VIN 9 engines came with dual outlet exhaust from the factory .........
I was already aware that some 307s came with dual outlets.
........ While not a true dual setup ........
Looks like the answer is, no, they did not come with dual exhausts.
Thanks.
Norm
odddoylerules
24
Jan 22, 2014 06:35 AM
delta254
Dec 3, 2012 08:37 AM
carbonf00tprint
Nov 4, 2012 07:53 AM
leo lymen
Dec 13, 2002 06:48 PM
