No spark at the points.
Old Aug 24, 2013 | 07:32 AM
tru-blue 442's Avatar
Old School Olds
Anyone ever had a problem with
power at the points, but no spark
between the gap?
It's like they are not grounded.
And no, the gap is not to wide
or too closed. New Sorenson coil as well.
Do you think a little grease under the base
of the points could help?
Old Aug 24, 2013 | 09:15 AM
Could be grease or possibly the condenser.
Old Aug 24, 2013 | 10:12 AM
Old School Olds
Well I now have a weak spark
with the points almost closed.
Short bursts at best.
I have a full 'bulb' my voltmeter
crapped out. Using a test light.
When I check the resistor wire
going to the starter solinoid,
the bulb goes dim. This is the
yellow w/black stripe.
Starter seem to have no issues,
but I am leaning towards the solinoid.
I will see if I have another condensor.
The one on it is new.
Side note: The red wire coming from
the other side is my remote starter wire.
The one going to purple on the solinid.
Old Aug 24, 2013 | 11:34 AM
Old School Olds
Just came back from round the block.
I guess the new condensor out of the box
was a piece. Dwell at *28, and rooma zoom zoom.
Thanks for the response Eric.
Old Aug 24, 2013 | 11:40 AM
No problem, set your dwell at 30, then advance your timing a few degrees. Your engine will thank you.
dynamic88builder
Dec 30, 2019 07:24 PM
malatu
May 5, 2008 09:24 AM
Specman
Mar 16, 2007 05:59 AM
For Sale
Mar 15, 2007 12:25 PM
