No spark at the points.
Anyone ever had a problem with
power at the points, but no spark
between the gap?
It's like they are not grounded.
And no, the gap is not to wide
or too closed. New Sorenson coil as well.
Do you think a little grease under the base
of the points could help?
between the gap?
Well I now have a weak spark
with the points almost closed.
Short bursts at best.
I have a full 'bulb' my voltmeter
crapped out. Using a test light.
When I check the resistor wire
going to the starter solinoid,
the bulb goes dim. This is the
yellow w/black stripe.
Starter seem to have no issues,
but I am leaning towards the solinoid.
I will see if I have another condensor.
The one on it is new.
Side note: The red wire coming from
the other side is my remote starter wire.
The one going to purple on the solinid.
viper771
Mar 11, 2013 06:57 PM
