Mini Starter who has tried what?
Old Aug 18, 2013 | 03:12 PM
lemoldsnut's Avatar
I am considering a mini high torque starter. Who has tried what and what kind of success have you had? Where is best to buy and so on? Thanks
Larry
Old Aug 18, 2013 | 03:31 PM
dc2x4drvr's Avatar
Powermaster
Old Aug 18, 2013 | 04:05 PM
Finn5033's Avatar
Powermaster
X2 I bought a power master through my local napa. Wasn't cheap but it works great.
Old Aug 18, 2013 | 04:34 PM
stevengerard's Avatar
X3 - you'll wonder why you didn't do this years ago - my car starts all the time now.
Old Aug 18, 2013 | 04:59 PM
X4 - powermaster.
Old Aug 18, 2013 | 05:15 PM
ROBZ442's Avatar
X5 for the powermaster
Old Aug 18, 2013 | 05:26 PM
2olds's Avatar
Best thing i ever did, Haven't had starter problems.
I used the summit starter protorque been in there for years.
http://www.summitracing.com/parts/su...bile/model/442
Old Aug 18, 2013 | 05:47 PM
OldsStarfire's Avatar
which powermaster?
Old Aug 18, 2013 | 06:34 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I bought the Powermaster XS 9510 used, worked great till I messed with it and shorted it out. Also bought the Summit mini starter, fine as long as you don't over tighten the marked connection, first one wasn't marked. Also bought an Ebay no name clockable mini starter, has worked fine, even grinding on the body so it would hug tighter on the 4x4.
Old Aug 18, 2013 | 07:15 PM
texxas's Avatar
I bought mine from this guy.
http://www.ebay.com/itm/NEW-PONTIAC-...ht_6246wt_1362
I didn't buy on eBay but had driven past his shop on numerous occasions when I was building houses in Grand Prairie and bought directly from his shop. I found him on eBay afterwards. I've been very happy with the starter, no problems in 4+ years of use. It took a couple of days to get used to the different gear sound on start up though.
Old Aug 18, 2013 | 08:27 PM
lemoldsnut's Avatar
Is eveyone using the 9510 or have any of you used other models? I don't care how it sounds as long as it works.
Old Aug 18, 2013 | 08:46 PM
Mine is a XS 9526, but I use it on a 468 Chevy, I run 10.5:1 compression with my timing @ 21 initial. The starter spins it over without a grunt.
The XS 9510 is the Oldsmobile equivalent to mine. The XS 9610 is a good starter also. They weigh less than 10 lbs.
http://www.summitracing.com/search/b...bile/year/1967
Old Aug 19, 2013 | 09:28 AM
ELY442's Avatar
I have the same thing that i bought from ebay last year. Its the Pro Tork. My Cutlass starts up very strong.
Old Aug 19, 2013 | 10:46 AM
LX89mustang's Avatar
I have this one also I got from Ebay . Price was $150 to my door and has worked great for the mild 455 I built for my car with headers . Best sounding starter I have heard from an older GM . Wish I had one of these back in the days of "heat soaked" no starting fun times
Old Aug 19, 2013 | 04:44 PM
ziff396's Avatar
I have had no problems to date with my UMI, off ebay, starter to date. Any wood around here?
Old Aug 19, 2013 | 06:02 PM
texxas's Avatar
Yes the pro tork. I notice the seller also has reman units for a little cheaper price.
http://www.ebay.com/itm/PONTIAC-OLDS...ht_6246wt_1362
w-30dreamin
Dec 15, 2012 12:55 AM
Troys Toy 70
Aug 6, 2012 04:14 PM
Alex72cutty
May 26, 2012 10:03 AM
rhaberm
Apr 19, 2011 09:58 AM
scott71
Mar 22, 2011 12:19 PM
