Mini Starter who has tried what?
I am considering a mini high torque starter. Who has tried what and what kind of success have you had? Where is best to buy and so on? Thanks
Larry
Larry
Best thing i ever did, Haven't had starter problems.
I used the summit starter protorque been in there for years.
http://www.summitracing.com/parts/su...bile/model/442
I bought the Powermaster XS 9510 used, worked great till I messed with it and shorted it out. Also bought the Summit mini starter, fine as long as you don't over tighten the marked connection, first one wasn't marked. Also bought an Ebay no name clockable mini starter, has worked fine, even grinding on the body so it would hug tighter on the 4x4.
I bought mine from this guy.
http://www.ebay.com/itm/NEW-PONTIAC-...ht_6246wt_1362
I didn't buy on eBay but had driven past his shop on numerous occasions when I was building houses in Grand Prairie and bought directly from his shop. I found him on eBay afterwards. I've been very happy with the starter, no problems in 4+ years of use. It took a couple of days to get used to the different gear sound on start up though.
Mine is a XS 9526, but I use it on a 468 Chevy, I run 10.5:1 compression with my timing @ 21 initial. The starter spins it over without a grunt.
The XS 9510 is the Oldsmobile equivalent to mine. The XS 9610 is a good starter also. They weigh less than 10 lbs.
http://www.summitracing.com/search/b...bile/year/1967
http://www.ebay.com/itm/PONTIAC-OLDS...ht_6246wt_1362
w-30dreamin
Dec 15, 2012 12:55 AM
Alex72cutty
May 26, 2012 10:03 AM
