Willys jeep with Olds V8
Old May 17, 2013 | 01:21 PM
Oldwolf's Avatar
****** jeep with Olds V8
Im in the progress of this build. I have searched the net for information but no luck so far. It would have been good if someone had some experiance about this type of engine swap. So far the major issue is cooling, space of radiator and fans I cant get space for a mecanical fan it has to be electrical. I send some pictures.
The car is a 1957 FC frame and a new flatfender WW II MB tub, fenders, hood and grill. please give me your thoughts.
Stanley
Old May 17, 2013 | 01:49 PM
cfhcar's Avatar
alot of guy that do v8 s10 use ford turas 3.8 electric fan. check this site has lot information http://www.s10v8.com/
cfhcar's Avatar
Smile
cool built!!!!!
Old May 17, 2013 | 01:53 PM
Oldwolf's Avatar
Great i check this.
Old May 17, 2013 | 02:01 PM
Oldwolf's Avatar
cool built!!!!!
Thank's I'm really exited about this "toy" actually this is crazy but really fun to do. I send some more pictures.
Old May 17, 2013 | 03:11 PM
Octania's Avatar
There is an Olds water pump that is 5.1" long - an inch shorter than the longest one. Perhaps the radiator can be moved forward a little using fabricated brackets?
and/or the electric fan
Great project!
Old May 17, 2013 | 03:26 PM
Oldwolf's Avatar
Great project!
i have a short pump (out of thre diffrent lengts) and it's nessesary I can tell. Right know i have only 3 inches from the pump flange to the inside of the grill ribs. I will have to move the engine and transmission rearby about 2 inches and trim the firewall so I can push the tub forward. The driveshaft gets even shorter. that way i know that I should have about 6.5 inch to the grill.
Old May 17, 2013 | 03:28 PM
RetroRanger's Avatar
72 Olds CS
I like it... I snapped a pic of this buggy at a stoplight the other day
Old May 17, 2013 | 03:43 PM
Wow that is close and I doubt there is enough room in front either.
Old May 17, 2013 | 05:31 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
You will probably be limited to only being able to use a short tail th350 transmission. A 400, 700r4 or a 2004r may not be able to mount due to the x frame interfering.
Old May 17, 2013 | 05:52 PM
f-85's Avatar
Were just finishing up the same swap on a 1947 Jeepster. It originally had an emissions olds 350 and now its getting a big block. And the 400 will NOT fit due to the X-frame. A 350 trans fits fine. Here's a couple pictures so you can see how we did the mechanical fan and radiator set up. Its tight but it works.
Old May 17, 2013 | 11:40 PM
Oldwolf's Avatar
I have the BOP Th 350 with a advance adapter and the Spicer 18 transfer case. It doesn't have to be a short tail. because you have to change to a shorter transmission shaft thats in the adapter kit. Lots of chevy sb swaps with this transmission setup have been made but not many with a Olds engine. It seems to be doable, with some tveaking. i will have to lower the rear to even the drive shaft angle but thats not a problem for me. I want it lower. The ****** have a perimeter frame so no interference with the frame, it's just very short.
Old May 17, 2013 | 11:43 PM
Oldwolf's Avatar
Nice, thank's for the pictures. As it seems you have a longer engine bay in the jeepster. That car is Cool.
Old Jun 5, 2013 | 03:51 PM
Oldwolf's Avatar
I have just finnished the engine and working with the belts. I have Questions regarding the crank pulley. it would probably Work but The crank pulley dont seem to match the water pump pulley. the pictures will tell. i have the short pump. does anyone know where I can get the right short crank pulley.
stanley
Old Jun 5, 2013 | 03:53 PM
Oldwolf's Avatar
stanley
Another picture
Old Mar 13, 2015 | 02:30 PM
Oldwolf's Avatar
It's slow but in progressiv. Drive train finished, and now brake Lines and steering in progress. Engine looks oldsish to.
Old Mar 13, 2015 | 02:59 PM
Oldwolf's Avatar
Old Mar 13, 2015 | 03:42 PM
don71's Avatar
same but different
Thanks for updating us. That in one cool project.
Old Mar 13, 2015 | 04:54 PM
cherokeepeople's Avatar
off topic but years ago i had a popular mechanics that they put a 330 in a cessna 175.that was cool
Old Mar 13, 2015 | 04:58 PM
http://wildaboutcarsonline.com/membe...-23_All_1.html
RAMBOW
Suspension & Handling
179
Mar 13, 2021 06:44 PM
HonestDave
May 10, 2014 05:57 AM
nonhog
Mar 10, 2012 04:39 PM
dmcianfa
Jul 6, 2011 07:20 PM
My442
Apr 25, 2011 05:19 PM
