1984 camaro seats in a 83 supreme?
Old Dec 7, 2012 | 05:27 PM
Wildcard's Avatar
i found a 84 camaro in a local scrap yard with bucket seats. will thay bolt into my 83 supreme 2dr? if not then what can i take seats out of that will work for my car?
Old Dec 7, 2012 | 05:52 PM
If you're taking out the bench seats, you'll need to install bucket seat mounts on the floor pans. The 2 types of seats are not interchangeable. Measure the height from floor pan to ceiling and compare that to the camaro seats. You can also use Grand Prix, Grand National, Monte Carlo, Buick Regal as donors. Just an FYI, Parts place makes the seat track mounts (part IN8514Z)
Old Dec 7, 2012 | 06:00 PM
Wildcard's Avatar
my cutlass has the seprate front seats. its the brougham version.
Old Dec 7, 2012 | 06:17 PM
Then you should be ok. Measure the distance side to side on the floor mounts, and front to back. If they're the same? Bob's your uncle. Can't see why GM seats from one car won't fit another.
Should advertise the seats for sale either here or on the G body forums. I'm sure someone somewhere will want some nice Brougham seats. I've even thought of doing that with another project car, but also want power adjustment, electrically heated, tilt seat back and lumbar support in the seat to meet my needs. Seems like the older I get, the more options I need for comfort.
Old Dec 7, 2012 | 06:32 PM
Wildcard's Avatar
i want just basic seats with the bar under the seat for the slider and the lever on the side for tilt. my stock plush seats are pretty rough. if i could, id convert my power windows to manual roll up ones. i hate power windows.
Old Dec 7, 2012 | 06:35 PM
You can convert them. Just need to go to the wrecker again and find manual handle regulators. Lot of work to remove then re-install though.
Old Dec 7, 2012 | 07:05 PM
carl 87 cutlass's Avatar
wildcard you may be better if you ordered new seats , I just ordered new seats for my 87 cutlass brougham from scat with tracks bare so I can fix them the way I want, check them out at scat.com good luck
stringbander
Dec 17, 2018 06:26 AM
Perry615
Apr 16, 2013 05:55 PM
lvelocci
Oct 21, 2010 10:50 AM
TOONLOVESCHERYL
Feb 17, 2010 11:40 AM
Winnipeg Cutlass
Apr 17, 2006 03:15 PM
