Question about throwout bearing install
Old November 9th, 2011, 07:27 PM
Kjr442
kjr442's Avatar
I am to the point of getting everything ready for re-installation of my trans. It has been a long long time sense I have messed with this,and can't remember which direction the "nub" or "stop" on the bearing is supposed to face. Should it face toward the fork or away from it? Just thinking about it, I would say toward the fork,but I am second guessing myself here.The assembly manual is not clear on this point. Any one?
kjr442 is offline
Old November 9th, 2011, 08:01 PM
Kjr442
kjr442's Avatar
Thanks, I do know how it works,but the groove for the fork has a spot that protrudes out, kind of pointed. I am not real sure which way to point it, toward the fork or away from the fork. So this is the area I am talking about, should it be like you see it here in the pictures or pointed the other way toward the fork?
kjr442 is offline
Old November 9th, 2011, 10:21 PM
Rickman48's Avatar
You've got it right!
Rickman48 is offline
Old November 10th, 2011, 07:34 PM
Kjr442
kjr442's Avatar
Well thank you, I pictured my old one just to show what I was talking about, I have it installed the other way right now,so I will pul lit out again and turn it around if you are sure.
kjr442 is offline
Old November 10th, 2011, 09:34 PM
Rickman48's Avatar
Big side has the bearing and should contact the fingers when pushed in - small flange is for return when released, and to keep the fork in position.
Old November 10th, 2011, 10:01 PM
Kjr442
kjr442's Avatar
Thank you , like I said I do understand how it works, I just did not know about the part that is somewhat pointed. You can see it in the picture. Is it supposed to be on the fork as pictured, or with the "out of round", "pointed part" of the fork grove positioned toward the fork?
Do you get what I'm asking ? If not let me know.
kjr442 is offline
Old November 10th, 2011, 11:46 PM
W70442's Avatar
I understand what you're asking and I don't really think it matters. As you said, the raised bump is simply a stop so the center of the bearing won't spin.
Looks like the old one has some wear marks on it. maybe you can look at those and decypher how it was installed before.
W70442 is offline
Old November 11th, 2011, 04:46 AM
Oldsmaniac's Avatar
In the one picture it looks like you have the TO bearing clip over top of the rear edge of the TO bearing. This is not correct. The clip and bent over part of the fork all go unto the groove. The bearing must pivot on the fork.... take it from someone who is on this road!
Oldsmaniac is offline
Old November 11th, 2011, 04:48 AM
Oldsmaniac's Avatar
Also I prefer the style TO bearing that is round and does not have the stop on it. It may hinder the pivoting action of the bearing.
Old November 11th, 2011, 05:37 AM
Kjr442
kjr442's Avatar
Thank you, I think I was over thinking this a little. Better safe then sorry! Right?
So do you agree that the "stop" can go ether way?
kjr442 is offline
Old November 11th, 2011, 07:01 PM
Oldsmaniac's Avatar
As I said I prefer not to use a TO bearing with a stop. My first attempt with my project car I used the one with the stop. I never saw or used this type before but figured it was the latest and greatest thing so why not give it a try.... When I had to take everything apart the TO bearing was jammed in the fork pretty tightly because of that raised stop. I had to pry it loose with a screw driver. While it may have been fine I had so many unknowns that I decided to use the TO without the stop as i was familiar with this type and never had a problem.
Old November 12th, 2011, 07:10 AM
Run to Rund's Avatar
As stated above, the entire ends of the fork, including the spring clips, go into the groove of the t.o. bearing. When done that way, you whould have clearance in the groove to wiggle the bearing on the fork so it stays straight on the tranny nose and contacts the pressure plate fingers straight and level, while the fork is changing its angle with its travel.
Run to Rund is offline
Railguy
June 24th, 2014 04:19 PM
junior supercar
Drivetrain/Differentials
October 11th, 2013 03:57 AM
Flye
July 30th, 2009 10:24 AM
Wild79Z28
April 12th, 2009 03:56 PM
dan2286
Brakes/Hydraulic Systems
March 16th, 2009 11:45 AM
Quick Reply: Question about throwout bearing install
