What to do with the Old Original Pistons?
Old May 29, 2026 | 02:00 PM
442b's Avatar
So, I have a 1969 Matching Numbers 442. I recently had the 400 engine rebuilt replacing all internal parts minus crankshaft. I'm wondering if I should hold on to the old Pistons or would they be worth selling? Any ideas would be helpful
Old May 29, 2026 | 03:01 PM
442Harv's Avatar
If they are in good shape and STD, sometime someone needs just one or two, to replace a couple bad ones. Not worth much but when that person that only needs a couple and does not want to buy a hole set, it helps him. If in bad shape, scrap steel
Old May 29, 2026 | 04:38 PM
That would be aluminum.
Old May 29, 2026 | 06:29 PM
Do any of them have a broken piston skirt or ring land? If so they'd make a good addition to your treasures.
Old Yesterday | 05:32 AM
442b's Avatar
They are all in good shape. No issues according to the machine shop that did the rebuild. Thanks for the responses
Old Yesterday | 10:45 AM
You could still keep them. I don't know if used pistons are valuable now, in 20 years they may be. Or, you could melt them down and use the aluminum to fill the exhaust crossover in your Oldsmobile and a few others. I don't know how far 1 piston of aluminum goes.
442b
Oct 31, 2025 09:53 AM
kevdog442
Jun 29, 2021 10:55 AM
grmchne78
May 12, 2016 09:21 PM
hoggster
Mar 16, 2016 03:49 PM
Stevec
Jun 4, 2012 11:29 AM
