Help Needed Pistons 69 442
Old Oct 29, 2025 | 10:34 AM
442b's Avatar
I'm not a motor guy so I really can't answer a bunch of questions, very limited knowledge about my car other than it is a numbers matching 1969 442 with a 400 G motor. I'm having the Engine rebuilt and the machine shop is having trouble finding pistons. He tells me it has the smaller pistons; he's boring it .30 over so needs to find pistons that are 3.900. All we've been able to locate is 4.030 pistons and those are too big. I spoke with Summit Racing, and they don't have a listing other than the 4.030 pistons. Any links or info would be helpful. Thank you
Old Oct 29, 2025 | 11:09 AM
442Harv's Avatar
Have you looked on Ebay? Also try Kanter for parts.
Old Oct 29, 2025 | 11:12 AM
Tri-Carb's Avatar
Contact Mark, a member that is both a piston dealer and an Olds engine builder:
https://www.truepeoplesearch.com/find/phone/8632063320
Old Oct 29, 2025 | 11:23 AM
Tri-Carb's Avatar
eBay does list some 400G plus 30/1000” pistons sold by Kanter brothers but I would first call Mark to explore all your options.
Old Oct 29, 2025 | 11:56 AM
Kanter and Egge pistons will be cast. I'd go with forged.
Old Oct 29, 2025 | 12:23 PM
442Harv's Avatar
Olds Performance, list a set $700
Old Oct 29, 2025 | 12:35 PM
I know for a fact that Egge supplies pistons in exactly the size you want because I used them in my 400G. However, as Joe points out, they will be cast. Back when I did my build they were the only ones I could find. There may be better alternatives now.
FWIW, I have no complaints with mine. For a mild street build I have found them perfectly acceptable.
Old Oct 29, 2025 | 02:41 PM
BillK's Avatar
Here is a set of .040's. I would buy them quick for that price. No difference boring 30 or 40.
https://www.ebay.com/itm/37606939375...Bk9SR-bbzp7GZg
Old Oct 29, 2025 | 02:55 PM
Except there are only four pistons in that auction ad.
Old Oct 29, 2025 | 03:31 PM
BillK's Avatar
I guess I didnt look close enough I would almost bet that pistons are out there though. Probably not that hard to find. Ill put out some feelers.
I have used several sets of Egge's pistons and they have been fine too.
Old Oct 31, 2025 | 09:53 AM
acavagnaro's Avatar
I have a set of AutoTec forged pistons that came out of a previous 400G build. I highly suspect that block was bored when built but can't say for sure - I'd have to measure it. If you're interested, I can measure the diameter of one of the pistons. Note I have 8 but one (or two - I don't remember) were damaged during disassembly. The rest are OK.
Nater357357
Jun 4, 2024 02:17 PM
Doug Carner
Jan 15, 2020 07:39 AM
Joe King
Dec 3, 2017 12:22 PM
grmchne78
May 12, 2016 09:21 PM
hoggster
Mar 16, 2016 03:49 PM
