Air cleaner decal
Old Mar 27, 2026 | 06:58 AM
BOZO442's Avatar
Air cleaner decal
[img alt="Just got 4in washer that goes under wing nut is that all I NEED TO HOLD 442 DECAL ON AIR CLEANER OR DO YOU USE GLUE? THANKS VINNE
"]https://cimg9.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/640x480/img_4099_8f89b8efeecb45a94045fb9ee6111a8f2c2dddcf. jpg[/img]
THANKS,
VINNE
Old Mar 27, 2026 | 07:04 AM
You need to edit your post and upload the picture properly. I tried to but I can't figure it out on my Droid.
FWIW, the air cleaner decals are adhered to the air cleaner. You can get reproductions at Fusick with sticky backing. I'm not sure what kind of glue they use that's heat resistant.
Old Mar 27, 2026 | 07:10 AM
Here.
1968s used "pie plates" which were pieces of metal. The sticker looks like it has a piece missing because it goes on the convex plate and it gets held down by the washer. 1969 uses a sticker on the air cleaner lid, no plate. Both use the washer and the nut. Dr. Decal is your sticker place.
So, a pie plate decal is only attached to the pie plate, and, is thus, removable from the air cleaner. A 1969 sticker is stuck to the lid. 68 is only held down by the wing nut and the washer.
Old Mar 27, 2026 | 07:11 AM
Thank you, sir. 👍
Old Mar 27, 2026 | 07:17 AM
Originally Posted by Olds64
Thank you, sir. 👍
you're welcome, no idea what was going on there. I dragged the picture out of his post.
Tancuda
Jul 4, 2024 07:29 PM
herkguy
Mar 13, 2022 07:29 PM
69 Hurst
Jan 26, 2020 04:56 PM
chip-powell
May 25, 2016 05:50 PM
jensenracing77
Jan 12, 2011 06:50 PM
