Tempest aluminum radiator
Old Nov 18, 2025 | 07:10 AM
73honey66 banana63cutelas's Avatar
I just ordered that Tempest aluminum radiator for my 62 F85. We'll see how it fits once it arrives. The only real issue with using it in an Olds is the lower outlet. On the factory radiator it has a 90 degree bend, but on the aluminum one it's straight.
so is this tempest radiator working in the 63 f85 ok??
Old Nov 18, 2025 | 07:39 AM
I moved your posts out of a 5 year old thread. You'll get more views this way.
I'm sure @joe_padavano will reply.
Old Nov 18, 2025 | 07:58 AM
jensenracing77's Avatar
Where are you located? You can have the original re-cored with a 3 core but you have to find a good radiator shop. There is a good one near Indianapolis if you are close. Some of the other 62-63 Jetfire guys ship their radiators to the guy in Indy.
Old Nov 18, 2025 | 01:17 PM
The Tempest radiator was a lot more work than I expected. Getting it to fit required some metal work and the 90 deg bend at the lower outlet was not going to work out. I shelved that project and have been using the brass three row I got from U.S. Radiator, which has been fine for cooling purposes. Flushing the system with Cooling System Flush from the Rust911 folks also made about a 10 deg difference in operating temperatures.
Old Nov 19, 2025 | 06:06 AM
i see there is a 63 buick skylark,, that looks like it may work great,, has the bend to it,, anyone use that one in the f85?
Old Nov 19, 2025 | 06:32 AM
This is the one I used, and I realize that I misremembered in my post above. The correct radiator has the elbow and the aluminum Tempest radiator did not. I was concerned about my TIG skills to add the elbow, and frankly the commercial elbows I found did not have a tight enough bend.
https://usradiator.com/product/oldsm...8-215-radiator
Old Nov 19, 2025 | 06:43 AM
X2 on the Buick and Olds being the same radiator.
Old Nov 19, 2025 | 07:14 AM
if you havent seen the 63 buick ,,skylark,, check it out,, itAluminum Radiator for 1962 1963 Buick Skylark 3.5L V8 Engine AT 62 63 - Picture 1 of 7 has the bend,,
Old Nov 19, 2025 | 08:22 AM
I think that is like one I have from a parts car and you have to modify the lower mounting brackets or make new ones. Not sure what these sell for new but I could sell my used one. It only had about 100 miles on it and like new. I will be out till Tuesday next week. Headed to MCACN in Chicago. WHere are you located, If interested in it I could bring it with me if you are near there
Old Nov 19, 2025 | 09:03 AM
oh goodness no,, i am near flint, michigan,, do you have you dimensions,, and guess on price and shipping??
Old Nov 19, 2025 | 09:04 AM
$125 free shipping
Old Nov 19, 2025 | 04:00 PM
sorry dont the text jargon,, i assume x2 means you agree, that the olds and buick are the same??
Old Nov 20, 2025 | 02:53 AM
Yes, same radiator. If they are that cheap I would go with the new one over my used one.
Old Nov 22, 2025 | 06:15 AM
i will be $143.50 shipped,, the fill is in center instead of offset like the olds,, but i will go and order one,, i dont think that will be a bad thing to drill and tap a couple holes
Old Nov 22, 2025 | 06:17 AM
i have seen that one,, very nice,, put pricey,, i kind of like the al too,, thanks for all your help
Old Nov 22, 2025 | 07:47 AM
it will be,, not i will be:
Guillaume
Nov 15, 2025 06:48 PM
WikedOldsmoileSupe88
Oct 6, 2023 01:49 PM
SLCJD
Jul 14, 2023 03:12 PM
57J2Olds
Jan 21, 2023 01:41 PM
65oldsf85
Jan 17, 2010 04:44 PM
