Frame date code
Old Jan 2, 2025 | 07:31 PM
dragline's Avatar
Frame date code
On a 1970 Cutlass or 442 is the frame date coded? If so where would it be located? Thanks
Old Jan 3, 2025 | 01:12 AM
Should be on the frame side rail, behind the left rear tire. The other four arrows are locations where the VIN derivative may be found, but on Oldsmobiles it is most frequently location #1.
It will look something like this. The upper number is the P/N. The 6 15 indicates June 15th. The S2 is second shift. There will be a two letter code to the right of the shift number that indicates the broadcast code for that frame (which you will find in a table in the Product Information Manual).
Old Jan 5, 2025 | 01:30 PM
dragline's Avatar
Appreciate the response, good info.
dragline
Dec 30, 2019 01:28 AM
Zr1bandit
Dec 10, 2016 11:33 AM
70sgeek
Oct 6, 2016 07:11 PM
droptopron
Feb 9, 2016 05:45 AM
costpenn
Aug 25, 2014 02:49 PM
