Frame numbers inquiry
Old Oct 6, 2016 | 02:29 PM
70sgeek's Avatar
'72 Cutlass ragtop
When cleaning the left rear frame rail after gutting the suspension for replacement, I was able to better decipher the factory numbers etched into it.
The top number was 6263668 which I know corresponds to the convertible frame p/n but I don't know if the code under it refers to a build date or some other production count - numbers are spaced apart somewhat and they don't match my vin.
4 12 72 1
The protect-o-plate is dated 6/15/72 which I presume is the original sale date to it's first owner, so it could make sense I guess if this code corresponded to the frame build date.
Is there decode info anywhere to check this?
thanks
Old Oct 6, 2016 | 02:45 PM
stevengerard's Avatar
would 4 12 72 be date of the frame was manufactured? Look on the frame where the drivers door would be. There will be a number that corresponds to the last part of your vin (or is it the sequence number can't remember) on the outside vertical piece of the frame.
Old Oct 6, 2016 | 04:21 PM
442Fred's Avatar
The "1" after the date is first shift.
Old Oct 6, 2016 | 07:11 PM
70sgeek's Avatar
'72 Cutlass ragtop
Makes sense then - that would be the right time line for it.
thanks!
jmills
Dec 28, 2013 08:12 AM
Funkwagon455
Aug 5, 2011 08:39 PM
jayarty
Jan 12, 2011 04:55 PM
Prophe'c
Oct 22, 2010 09:16 AM
wjustinmartin
Drivetrain/Differentials
Mar 20, 2010 03:18 PM
