Correct type of battery
Old Nov 7, 2024 | 07:02 AM
orlandod's Avatar
I just picked up an 84 Hurst Olds and need to get a battery for it. My RPO code refers to UA1 Battery, Hevey Duty.
Does that mean the car originally had a Group 78 or a Group 75 battery?
The other reason for this question is the plastic base where the battery sits appears originally to have four plastic tabs to keep the various battery sizes in place. Mine now has two of the tabs broken off to accommodate the larger 78-battery as the picture shows.
Comments are appreciated. Thanks
Old Nov 7, 2024 | 07:28 AM
zl1 camaro's Avatar
Group 78 is heavy duty >> group 75 is standard. IF the group 78 fits I would use that.
Old Nov 7, 2024 | 12:01 PM
69HO43's Avatar
You posted this question in another thread, so I'll post this here again. It's my original HD battery from my 85 442 with RPO UA1. It's a 75 series. I think they used 78s in the Chevies. Not sure though. The 78s were a tad wider. If you get the right hold down bracket, the 75 series or 78 series can be used and not float around even with the tabs broken. You can't fix the tabs once they're gone, though. If you're lucky enough and find a Cutlass with a Chevy engine in it, I think they put the batteries over on the "wrong" side and the driver side tabs hopefully remained intact if you wanted to use a 75 battery. So greater chance the tabs wouldn't be broken.
The decals migh look different, and I think it was white with a BLUE top in 1984, with a white body, but they used the same sized 75 series batteries in 84 as they did in 85.
Old Nov 7, 2024 | 12:08 PM
orlandod's Avatar
69HO43
Sorry for the duplication and I appreciate the info which confirmed my suspicions. I am looking into getting a 75 series battery with side posts. Thanks
Old Nov 7, 2024 | 12:33 PM
69HO43's Avatar
I can tell you that your battery cables aren't factory, and the positive cable is routed incorrectly. It normally goes along on top of the driver valve cover and down the phenolic tube at the rear of the engine to the the starter. The negative side goes to the stud near #1 spark plug hole.
Old Nov 7, 2024 | 12:52 PM
orlandod's Avatar
I appreciate the factory correct info and I will file this information for when I start to detail the car but for now, I need to get the thing running. On that note, in your picture, I am missing the air duct from the radiator to the air cleaner. I have the plastic piece still attached to the rad but the tube and adapter that fits over the snorkel is missing. Is that a part that can be found readily? Thanks
orlandod
Nov 6, 2024 11:27 AM
maddoctor
Oct 24, 2024 04:39 AM
Jon442
May 10, 2021 07:31 AM
Oldssupreme
Nov 8, 2019 10:46 AM
VikingBlue
Feb 11, 2012 10:24 AM
