fuel tank paint
The original tanks were NOT painted. If you're buying a replacement tank made by Spectra Premium (Canada) it will look like the original finish. They use a "special" type of coating or metal called "Ternes" steel. No need to paint it at all.
Don't get talked into painting it if you want an original look. The typical gas tank paint sold by places like Eastwood doesn't look like the original finish at all.
Even if you don't paint the exterior of the tank you might consider coating the inside before you install it. I've used the POR-15 fuel tank lining kits on 2 fuel tanks. The tank of my 71 98 and the tank of my 86 Ford F250. Both tanks were in decent condition when I started and are ready for another 20+ years of service after treatment.
https://por15.com/products/fuel-tank-repair-kit
Barry
Barry
Just a thought, seems to me that shooting the tank with a catalyzed matte or semi matte clear wouldn’t much show unless you were right up against it, would be solvent resistant and protect the tank nearly forever.
