67 442 new
Old Oct 29, 2023 | 02:24 PM
mbrooks281's Avatar
power steering fluid leaking cap vent
Hello, anyone have an issue with power steering fluid coming out the vent of the cap? I haven't done anything recently nor have I added any fluid..
Last edited by mbrooks281; Oct 29, 2023 at 02:51 PM. Reason: posted in the wrong thread
Old Oct 30, 2023 | 05:02 AM
zl1 camaro's Avatar
Have you turned the wheels while the engine was not running maybe ? sounds like maybe a line is partially plugged causing pressure to build up..is the fluid aerated [air bubbles in the fluid] causing a build up of pressure.. Does the steering act ok ?
Old Oct 30, 2023 | 06:55 AM
Moreover, do you get any strange noises when you turn the wheel?
Old Oct 31, 2023 | 03:23 PM
mbrooks281's Avatar
not at all, its strange I can see it bubble out with car at idle..
Old Nov 1, 2023 | 04:39 AM
zl1 camaro's Avatar
Something is restricted or the return line is sucking in air, even if it shows no signs of leakage. The fact you are seeing it come out of the reservoir with air bubbles, really look at the return hose.. I would look here first.. I know that sounds strange but I have seen this many times.. keep us posted....
Old Nov 1, 2023 | 08:35 AM
mbrooks281's Avatar
thanks! I will check that this weekend.
Old Nov 9, 2023 | 07:31 PM
mbrooks281's Avatar
sorry for the delay, nothings clogged up so my only assumption is to much fluid. I drained some of the fluid yesterday. It's been pouring here the last 24hrs. Ill let you know in the next couple days..
Old Nov 9, 2023 | 10:31 PM
cfair's Avatar
Even if system is working, heat causes the PS fluid to expand, which can cause a burble or eruption out of the top pressure release valve if the fluid level is high enough.
The fix is get a cooler (heat exchanger) or run less fluid.
Wish I had better news.
Chris
Old Nov 10, 2023 | 04:24 AM
zl1 camaro's Avatar
NOT to beat this to death. I thought you had said that you never had any issues with this, so I assumed you never added any fluid to this in the first place ? [so how did this get so full ??] Which brings me back to >> is the return line sucking air into the system causing this to over flow ? Also as one post said, heat can also cause this as well, but that usually goes back to a blockage or relief valve in the pump. [MOST FOLKS JUST REPLACE THE ENTIRE PUMP IF THIS IS THE PROBLEM] [No need to however if just the valve] I do not think you need a cooler because this car never had one & has been good for all these years without one. You need to find the root cause.. keep us posted & of course good luck..I don't want to come across as a know it all, but I have had experience with this in the past. But maybe there is another issue that I never saw before.
Dream67Olds442
Aug 15, 2020 12:12 PM
dmw
Jul 15, 2019 01:44 AM
dinanm3atl
Nov 11, 2018 05:24 AM
1966Oldsmobile
Brakes/Hydraulic Systems
Mar 22, 2013 02:54 PM
Jetstar 88
Apr 17, 2012 04:25 PM
