Spare?
Old Mar 3, 2023 | 10:18 PM
Carsick's Avatar
Spare?
I have a 1969 442. I have one original tire (Goodyear polyglass). I want to do a good looking spare in the trunk with it. Please help!
The question is, am I stuck using an ssii wheel or is there something else that might fit better? The other wheels are all 14" ssii. The tire is a 14" too.
Not mine but an idea of what I'm thinking. How did they place the spare from the factory?
Old Mar 3, 2023 | 11:23 PM
hurst68olds's Avatar
ALL 5 tires & wheels were the same - got pics of your original spare?
Old Mar 4, 2023 | 05:53 AM
If the car came from the factory with SuperStock wheels, the spare was also a SuperStock wheel. Cars with SuperStock wheels had the jack handle mounted in clips, unlike cars that had plain steel wheels.
Old Mar 6, 2023 | 06:22 PM
Bryan Burch's Avatar
I need to paint my jack for my 69 442. Pretty sure the base and handle are black, but the jack assembly and post are spraypainted silver. Is that correct?
Old Mar 6, 2023 | 06:52 PM
Carsick's Avatar
Thanks for the great info Joe. So black?
Old Mar 6, 2023 | 07:04 PM
If you are asking about SSII/SSIII wheels, they were either Argent or body color, to match the other four.
Old Mar 6, 2023 | 07:24 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Was the spare SSII a bare wheel with no trim on it?
Old Mar 6, 2023 | 08:30 PM
do you have a picture of your spare? I asked because at the beginning of the 1969 model year - the REDLINE was the only POLYGLAS available & the RWL GOODYEAR tire was a "Goodyear Speedway" with "WIDE TREAD F70-14" in RWL - not sure if a RWL Polyglas became available later in the model year ??
Old Mar 6, 2023 | 09:18 PM
Carsick's Avatar
I was actually referring to the holder.
Old Mar 7, 2023 | 03:32 AM
It came with the bezels and the bolt-in center, but no trim ring. You were supposed to transfer the trim ring from the wheel with the flat (just like the hubcap for cars with those).
The holder for what?
Old Mar 7, 2023 | 07:45 PM
Carsick's Avatar
For the spare...I have raised white letter tires not like it came with I know.
Old Mar 7, 2023 | 07:54 PM
SS wheels sat face up like in that diagram. Steel stamped wheels sat face down and used the jack base and a longer stud and a big wing nut to be held down. Bear in mind that all of these wheels were recessed compared to the tire on the side facing down, so it really just is a rubber inflated tire sitting on the trunk pan. Nothing will fit better or worse, unless you have something that pokes down lower than the bead on the bottom side.
If you want more room, get a universal donut that is smaller.
Old Mar 11, 2023 | 03:31 PM
Carsick's Avatar
All black for the spare holder? Semi gloss I guess?
Thanks for those diagrams!
Old Mar 11, 2023 | 04:23 PM
I'm sorry, but what exactly are you calling the "spare holder"? The WHEEL? The jack base? The nut?
Old Mar 11, 2023 | 07:23 PM
Carsick's Avatar
The base I guess? All I have is this spare and some random 'spare' parts in the trunk. I haven't gone through it to see what's there I'm just assuming it needs a bit of tlc. When you open the trunk all you should see is the spare?
Old Mar 11, 2023 | 09:44 PM
See the above sticker. Your wheel, right there, sits in the trunk face up. It has a center cap on it, and the trapezoids on it. Factory, you did not get a fifth trim ring, but there is no reason why you could not buy one. Your lug wrench is semi-gloss black, it fits in clips shown. Those clips were probably parkerized.
The bumper jack, which should not be used unless in emergency, sits under the tire. The stick is zinc chromide. The mechanism is semi gloss black, the base is semi gloss black. The bumper hook is semi gloss black. It has a pad for the bumper. They sit under the tire in a way that works, just wiggle it around. The bolt hook goes through the hoop in the trunk floor. It is parkerized.
Stick it up through a lug hole. Attach nut, which is parkerized. Hand tighten to start. Tighten by hand as much as you can go, then put a little bit from the lug wrench on it. Stow wrench.
Old Mar 12, 2023 | 02:05 PM
Carsick's Avatar
Thank again. Should I respray the trunk area with splatter paint (I think that's what it's called)?
Old Mar 12, 2023 | 02:13 PM
Yes. Fusick and other places have it. Get the right one for your year. A trunk mat is also a good idea, available repro.
Old Mar 12, 2023 | 02:57 PM
Carsick's Avatar
I didn't know there was a mat too, thanks!!
Old Mar 12, 2023 | 08:34 PM
Carsick's Avatar
Is this the date the tire was made '76?
Old Mar 12, 2023 | 08:37 PM
Carsick's Avatar
now for the mat!
Old Mar 12, 2023 | 08:38 PM
Carsick's Avatar
now for the mat!
Old Mar 13, 2023 | 04:44 AM
Oldsguy's Avatar
Past Administrator
https://www.chapelhilltire.com/how-t...20manufactured.
Old Mar 13, 2023 | 12:37 PM
it's going to be on the backside of that tire & look like this one from '73
Old Mar 13, 2023 | 01:14 PM
Carsick's Avatar
Thank you is this it?
Old Mar 13, 2023 | 01:33 PM
last 3-digits "432" = 43rd week of 1972
Old Mar 13, 2023 | 11:29 PM
Carsick's Avatar
Thank you...for some reason I wasn't getting it.
JOHNNYOLDS442
Wheels and Tires
Mar 12, 2023 02:07 PM
Tom Bilse
Wheels and Tires
Jun 19, 2019 03:17 PM
72442455
Wheels and Tires
Apr 8, 2019 04:06 PM
Mar 15, 2019 05:17 AM
mike623
Jan 18, 2011 11:35 AM
