1970 sport mirror cable replacement
Old Sep 28, 2022 | 08:27 AM
4+4+2=10's Avatar
Can the remote cable be replaced on a driver side 70 sport mirror and if so what is involved?
tc
Old Sep 28, 2022 | 08:46 AM
PatL's Avatar
tc
I have not seen the cable reproduced, but could be wrong. What are the symptoms ?
Not alot can go wrong with it, but I can tell you from personal experience I had mine get hung up in the window mechanism when I was putting the door panels back together. There is a welded in clip on the door that the cable should fit in to keep it from binding on anything. I saw that when I was trying to resolve the issue
Old Sep 28, 2022 | 10:37 AM
4+4+2=10's Avatar
Cable is functional, but the controller is a little on the ugly side. I have another one on a standard remote mirror I would trade out if I can.
Old Sep 28, 2022 | 11:18 AM
Del70's Avatar
I swaped the "controler" out, had an issue with it so had to be done. It was not easy. I had to open up each swage/compressed metal area of the housing some to get each cable end to push out, and to get the cable free of the housing, did this a long time ago, I think there were other challenges too. Again was not easy,., but was able to change it out. Maybe there are other methods to replace cable /controler at the mirror end?.
Old Sep 28, 2022 | 05:55 PM
4+4+2=10's Avatar
Originally Posted by Del70
I swapped the "controller" out, had an issue with it so had to be done. It was not easy. I had to open up each swage/compressed metal area of the housing some to get each cable end to push out, and to get the cable free of the housing, did this a long time ago, I think there were other challenges too. Again was not easy,., but was able to change it out. Maybe there are other methods to replace cable /controller at the mirror end?.
Thank you...I will look into this option with my parts. a controller swap would accomplish my goal. I'm assuming a similar procedure is required behind the mirror glass but would likely require getting the glass out of the way. I see new glass is available and even available with a new die cast backing plate with what looks like cable attach points. I was just hopeful someone here had approached this job and could offer a pointer or two.
tc
Old Sep 28, 2022 | 08:14 PM
70Post's Avatar
You should avoid the repro die cast backing plate setup.....have had a couple just randomly break and then the mirror glass falls out. I think in one case it was the "pin" that is pressed into the diecast pedestal that broke....or slipped out. Just went and looked at a repro pedestal a second ago and it has 3-4 cracks in the casting (never used) and one of the travel limiter pins was also broken off. Real junk but not surprising given it's a repro part.
They apparently use some REAL junky diecast material for the repro die cast backing plate (better described as the "pedestal")
The mirror glass itself can be replaced as you noted.
Old Sep 29, 2022 | 07:05 AM
4+4+2=10's Avatar
Thank you Patton..
hershillgn
Apr 29, 2020 10:49 PM
tdhill01
Sep 17, 2019 03:43 AM
WannaBa442
Sep 9, 2017 08:09 AM
csouth
Apr 20, 2017 04:34 PM
rallyeman1
Nov 24, 2015 05:49 PM
