69 442
Old Sep 7, 2022 | 10:29 AM
fourfortyduece's Avatar
69 442
hello. what is the best way to remove plugs from behind the ac compressor and the rear plug? thanks
Old Sep 7, 2022 | 10:47 AM
VC455's Avatar
Barely Registered
I bought a spark-plug socket with hex on top. I use an open-end wrench on the socket's hex for the back plug by the A/C box.
I don't recall specifically what I use for the plug behind the A/C compressor--I must use something fairly common that I already have in my toolbox.
Old Sep 7, 2022 | 10:56 AM
thanks man. ill go to that one first. steve
Old Sep 7, 2022 | 11:07 AM
v8al's Avatar
Registered Olds Owner
FYI - How do I replace to passenger rear spark plug?
Old Sep 8, 2022 | 06:56 PM
geardoc66's Avatar
I find that one is easy to get to from underneath. Jack up the car a reach up, there is a lot more room for your hand. If you must go from the top, a long extension with a swivel spark plug socket will usually work.
Old Sep 9, 2022 | 10:18 AM
thanks for the reply. my hands barely fit. i finally got it started last night. no i have to make about a 100 1/16 turns to get it on. i did order a sidewinder socket wrench should make it a hell of alot easier in the future. steve
Old Sep 9, 2022 | 10:31 AM
I use a swivel adapter
Old Sep 9, 2022 | 01:23 PM
VC455's Avatar
Barely Registered
Originally Posted by fourfortyduece
...a sidewinder socket wrench should make it a hell of alot easier in the future...
I had to look up what a sidewinder was. Very clever! Let us know how it works on that job.
Old Sep 9, 2022 | 09:12 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
#8 Plug removal assembly. The only other item you may need is a plug boot puller.
Boilerz25
Nov 17, 2022 12:41 PM
72455
Apr 9, 2022 07:32 PM
ho69john
Hurst/Olds
Dec 16, 2016 06:55 PM
ent72olds
Mar 3, 2013 12:22 PM
derek nesdoly
Jun 14, 2010 02:13 PM
