Original radio install 72 cutlass
Old Sep 1, 2022 | 07:31 AM
72442455's Avatar
Joe Ralph
I acquired an original 72 am radio for my 72 at homecoming - I have the lower bracket shown above - but am missing the longer arm circled in photo - can someone enlighten me to it’s purpose and if I need that to install it? (The radio is for looks only - running a blue tooth set up separate from radio - but plan to get old radios lights working)
Old Sep 1, 2022 | 08:48 AM
You can probably get away without it if you have the other support/ground strap.
Old Sep 1, 2022 | 08:54 AM
Those brackets are to increase the stiffness of the radio mounting so that vibrations from driving don't cause that insanely heavy radio to break the plastic dash.
Old Sep 1, 2022 | 09:07 AM
scrappie's Avatar
If that plastic strap isn’t there, it will be a big PIA attaching the one end to the center dash vent up top.
Old Sep 1, 2022 | 10:02 AM
72442455's Avatar
Joe Ralph
Originally Posted by scrappie
If that plastic strap isn’t there out will be a big PIA attaching the one end to the center dash vent up top.
so that long skinny one is plastic? Is it reproduced?
Old Sep 1, 2022 | 10:51 AM
72442455's Avatar
Joe Ralph
is this the strap?
Old Sep 1, 2022 | 10:52 AM
72442455's Avatar
Joe Ralph
I have this
Is this the long skinny thing I circled in my original pic?
And do I need this to make the light work (radio won’t be used) and does this add any support to the radio?
Old Sep 1, 2022 | 10:53 AM
scrappie's Avatar
There you go
Old Sep 1, 2022 | 10:54 AM
72442455's Avatar
Joe Ralph
There you go
ok - ordering the plastic strap and the ground strap then - thanks
Old Sep 1, 2022 | 10:57 AM
72442455's Avatar
Joe Ralph
Where do you attach the radio ground strap? Csm doesn’t show it best I can tell?
Old Sep 1, 2022 | 11:02 AM
70sgeek's Avatar
'72 Cutlass ragtop
If the radio section won't be used you can possibly gut some of its audio-related circuitry to shave off some chassis weight.
Of course, if you were to have it rebuilt into a stereo/blue-tooth conversion, literally all of those heavy guts would be replaced by a some lightweight updated circuitry
a pricier but cool option is this OEM-based stereo/blue-tooth set from Antique Automobile Radio - https://radiosforoldcars.com :
Fractionally compact size compared to the OEM box and essentially negligible weight.
Old Sep 1, 2022 | 11:13 AM
72442455's Avatar
Joe Ralph
thanks - but I already have everything I need for my stereo - just trying to mount the original in the dash without screwing up the dash plastic and all that
Old Sep 1, 2022 | 03:31 PM
I've used plumbers strap for many in dash radio supports.
Old Sep 1, 2022 | 03:39 PM
72442455's Avatar
Joe Ralph
thanks - attach it from the same bolt the lower bracket goes to and up to the center of the a/c vents? (Read that in another post here)
Old Sep 3, 2022 | 07:54 PM
BSiegPaint's Avatar
From the back view of the dash, here’s where that strap attaches
Old Sep 6, 2022 | 05:05 PM
72442455's Avatar
Joe Ralph
weird - it looks like a solid metal bar in the picture - which is what I thought it was in the line drawing of csm …
Old Sep 6, 2022 | 05:07 PM
72442455's Avatar
Joe Ralph
thanks tons for the picture - I get it now! Took me a bit looking at it to see what I was looking at - that helps tons!
NorthBay72supreme
May 20, 2021 08:02 PM
KDW
Jan 14, 2014 08:15 AM
webby
Jan 16, 2012 02:44 PM
ELECMAN
Feb 27, 2011 03:43 PM
ELECMAN
Nov 1, 2009 06:54 PM
