checked some numbers just to be curious
Old Jun 18, 2022 | 07:31 AM
Nichelson 1970's Avatar
I have been going over the Rallye 350 that my wife bought recently & have been tightening up nuts & bolts that the guy that sold it to us overlooked or missed while freshening up the underhood area.
I checked the carb numbers & the distributor numbers & will list them so you Olds gurus can enlighten me on whether they are correct parts for this Ralley.
Carb is stamped 7040253 & 2709 Distributor is stamped 111975 & 0A15 car was built in first week of Feb. 02A on cowl tag.
Old Jun 18, 2022 | 01:07 PM
2blu442's Avatar
The carb number is correct for a 1970 4 speed car. Is your Rallye an automatic or manual transmission?
Old Jun 18, 2022 | 02:53 PM
70W-32's Avatar
Youve probably missed a 1 in the dist. number, making it 1111975 which is correct for a 1970 350 4bbl. the date is Jan 15 1970, so it is within the correct range for Her car
Old Jun 18, 2022 | 03:40 PM
tnswt's Avatar
'70 4-Speed W Machine
It's a 4-speed according to OP's past threads about the car......
Old Jun 18, 2022 | 06:20 PM
its a 4 speed
Old Jun 19, 2022 | 06:04 AM
'253 is a manual trans 442 carb for a 455. A Rallye 350 used the '250 carb for both MT and AT applications.
EDIT: see my post below. The QB code 350 did use the '253 carb starting in late Nov. 1969.
Old Jun 19, 2022 | 04:30 PM
Rallye is a 4 speed
Old Jun 19, 2022 | 04:48 PM
Originally Posted by Nichelson 1970
Rallye is a 4 speed
It still came from the factory with a 7040250 carb.
Old Jun 21, 2022 | 07:34 AM
tnswt's Avatar
This thread may interest the OP.....
https://classicoldsmobile.com/forums...-carb-s-11736/
Old Jun 21, 2022 | 07:44 AM
My apologies. The carb usage chart I posted above is apparently from early in the model year. Below is the table from the 1970 Engine Assembly Manual that clearly shows the QB code 350 using the '253 carb. Note that the change was made Nov 21, 1969. Sorry for the bad info earlier in this thread.
Old Jun 21, 2022 | 11:19 AM
tnswt's Avatar
That's cool Joe P.
I still say you have forgotten more about Oldsmobiles than most of us will ever know.....
deadeyejedi
Jul 19, 2021 06:06 PM
vickycar
Aug 12, 2017 07:20 AM
dfire25
Apr 2, 2014 01:08 PM
oldzzy
Oct 26, 2013 03:58 PM
