Distributor codes
Old Jul 19, 2021 | 05:10 AM
deadeyejedi's Avatar
Distributor codes
I get the last 4 numbers to determine year month and day of manufacture , but what are the first 5 characters ? For instance my 1972 cutlass dist. Reads lll 2226 2k27. So if I’m correct the last numbers mean 1972 nov.27? What about the first 5? Thanks you
Old Jul 19, 2021 | 07:53 AM
Tri-Carb's Avatar
The Letter "I" is skipped to avoid confusion with the numeral "1". The letter "K" represents October in the applicable convention.
The numbers preceding "2K27" are the part numbers for the make. model and year(s).
Old Jul 19, 2021 | 08:08 AM
rcorrigan5's Avatar
Randy C.
The first numbers (1111226) indicate the part number for the distributor. As Tri-Carb demonstrated, the 2K27 means 1972 (2), October (K) 27th, which would tell me a distributor of that date would be original to a 1973 model year car.
Randy C.
Old Jul 19, 2021 | 08:10 AM
Thank you so my question now is there a way to tell what make and model the dist. Came in based on the first set of numbers
Old Jul 19, 2021 | 08:23 AM
Randy C.
based on that it would tell me my distributor is not the factory original ( my bad on the nov . Month )
Old Jul 19, 2021 | 06:06 PM
Yellowstatue's Avatar
1972 350 2 bbl--1112079, also with 4bbl & manual; w/455 1112033 but not w OAI; 1112085 350, 4 bbl w/AT; try that.
Mar 14, 2021 05:23 PM
vickycar
Aug 12, 2017 07:20 AM
oldsmike1972
Oct 11, 2014 10:41 AM
70sx455
Jun 25, 2014 10:16 AM
70sx455
Oct 21, 2010 02:22 PM
