Teflon tape or no?
Old Apr 14, 2022 | 11:28 AM
FINISHLINE's Avatar
Teflon tape or no?
Is it a good idea to put a thin wrap of Teflon tape on fittings like power steering hoses, transmission lines into the radiator etc?
Old Apr 14, 2022 | 11:36 AM
nicks1966's Avatar
the seal is on the flare not the threads, so teflon tape does no good.
Old Apr 14, 2022 | 11:51 AM
bw1339's Avatar
Teflon tape only belongs on tapered threads (NPT). Everywhere else, you are interfering with the way the joint is supposed to seal.
Old Apr 14, 2022 | 12:09 PM
Sugar Bear's Avatar
No to the Teflon tape. Put a touch of anti-seize between/under the nut and the line (not on the sealing surface) and on the threads to aid in future disassembly.
Old Apr 14, 2022 | 12:36 PM
VC455's Avatar
Barely Registered
The tape only has a positive function if you are careful to put it only on the threads and under the nut. There, it helps clamping force to give you a better seal. If you get any on the sealing surface, it may interfere with a good seal.
Best to do as Sugar Bear suggests.
Old Apr 14, 2022 | 01:36 PM
FINISHLINE's Avatar
Thanks All!
Old Apr 14, 2022 | 03:30 PM
Think this through. The seal is made on the flare, as shown by the red arrow. If you need to put teflon tape or other sealer on the threads, what prevents a leak between the flare nut and the tube (yellow line)?
One thing you SHOULD do on flare nuts is to apply a very small amount of anti-seize to the tube where the flare nut sits and to the threads on the flare nut itself. Do not get any anti-seize on the sealing surface of the flare, however.
Old Apr 14, 2022 | 04:07 PM
FINISHLINE's Avatar
Makes sense. If the flare wasn't properly "seated" the only thing the Teflon might do is stop the leak from showing on the outside. Correct?
​​​​​​Also, isn't there several types of antiseize. Some more easily "broken free," than others?
Old Apr 14, 2022 | 04:34 PM
No, the leak will follow the yellow line and seep out between the flare nut and the tube.
To be honest, I haven't found a lot of difference between the nickel and copper loaded anti-seize in this application.
Old Apr 14, 2022 | 04:46 PM
FINISHLINE's Avatar
Ahhhhh. I see what your saying. So the method here would be to to advance that flare into position and make sure it's "seated", and THEN thread the nut.
Old Apr 14, 2022 | 06:22 PM
66-3X2 442's Avatar
My engine guys turned me on to Teflon pipe sealer used by plumbers on NPT connections. Available everywhere plumbing supplies are found. When tightened you can wipe the excess off for a neat clean look, no ugly white tape showing.
Old Apr 15, 2022 | 03:16 AM
fleming442's Avatar
Fun fact: gear oil and Teflon tape don't play well together. Just learned this one first hand.
Also, the Teflon is to lubricate the threads, not fill the gaps.
Old Apr 15, 2022 | 07:06 AM
Hammerdrop's Avatar
[QUOTE=Also, the Teflon is to lubricate the threads, not fill the gaps.[/QUOTE]
I think the teflon can be useful to block the infiltration of undesirable moisture into the thread area especially in rust belt states, but maybe not so much on hobby vehicles.
Old Apr 15, 2022 | 08:25 AM
Sugar Bear's Avatar
Our Teflon theories never seem to stick...but sometimes they do hold water.
Old Apr 15, 2022 | 08:27 AM
Old Apr 15, 2022 | 05:23 PM
FINISHLINE's Avatar
Lmao
Old Apr 15, 2022 | 06:06 PM
Lmao
And here I expected someone to ask if that was a selfie...
Old Apr 15, 2022 | 06:07 PM
66-3X2 442's Avatar
It's not?
Old Apr 15, 2022 | 06:08 PM
It's not?
A selfie wouldn't look as good.
Old Apr 15, 2022 | 06:41 PM
FINISHLINE's Avatar
I gotta say...Tinkering with this old car combined with chatting with you fine folks on this site is so damn enjoyable!!!
Old Apr 16, 2022 | 05:20 AM
Bfg's Avatar
Bfg
You should at least trim the hairs growing out of your ears
Old Apr 16, 2022 | 06:16 AM
My kid used to ridicule me about that. I told him it was hereditary and his time was coming. Guess what? It did.
dbaum
May 31, 2018 10:35 AM
jaunty75
Jul 10, 2017 03:04 PM
jag1886
Apr 11, 2014 02:58 PM
bapa1944
Jan 3, 2014 04:36 PM
WHIPOLDS
Nov 13, 2011 06:07 PM
