Fan Clutch Information/Advice
Old Jun 29, 2021 | 06:28 PM
Bigmikey65's Avatar
I am restoring my ‘70 W30. It’s a 4-speed car with HD cooling. IF I decide to hunt for an NOS fan clutch what is the correct part # ? (I have seen #401797 and #4949861). What is the correct part # for my application ?
IF I decide to buy a correct used fan clutch I would obviously have it restored mechanically and aesthetically. I recall a Corvette guy ?? that does this type of work but it’s not cheap ? Anyone have a ballpark figure of the cost to restore and his contact info ?
Thanks guys - Mike.
Old Jun 30, 2021 | 05:16 AM
The PIM shows 401797 with 4939873 as an equivalent option (both are stamped "OS").
4949861 (code "OR") is shown in the PIM as used on 1970 A/C cars, so not a W30 4spd.
My Jan 1972 Parts Book shows 4949861 as applicable for just about every HD cooling application (A/C, O.A.I., etc). I suspect this is a case of one part number superseding the factory-installed part number for replacement purposes. Another example of why you can't rely on the Parts Book for info on how the car left the assembly line.
Old Jun 30, 2021 | 06:51 AM
Bigmikey65's Avatar
Thanks Joe.
Old Jun 30, 2021 | 07:55 AM
MI68442W30's Avatar
the OS is also correct for my 68 with heavy duty cooling and I would also like to know if there is anyone out there that can restore a clutch assembly as I have a couple of used clutches that need new bearings and seals
Old Jun 30, 2021 | 10:23 AM
Bigmikey65's Avatar
Is it correct to say that a ‘70 W30 with a 4-speed and a 3.42 rear came stock with a 3 core radiator, straight 4 blade fan (no fan clutch) and no radiator shroud ?
Could you upgrade (order and pay for the option) to the Heavy Duty Cooling Option on this car as equipped ? If you could - what did you get in the package (ex. 4 core radiator, clutch fan, shroud etc.) ?
Is this the difference between V01 and V02 ?
Thanks - Mike
Old Jun 30, 2021 | 12:52 PM
tnswt's Avatar
'70 4-Speed W Machine
Fan clutch repair:
Kirkconnell Corvettes
9710 Sunbeam Dr
New Port Richey, FL 34654
Diane Kirkconnell K63vette@msn.com
Old Jun 30, 2021 | 03:42 PM
MI68442W30's Avatar
thank you ,I will look into Kirkconnell
Old Jun 30, 2021 | 04:57 PM
joesw31's Avatar
The correct code for your fan clutch is “OR” and not “OS”. Your repair manual will show “OR” and the PIM shows or “OR” as well. The application is 4400, 4800 with C-60.
The 4400 is separated with a comma. The next application is 4800 with C-60 which is a vista cruiser with A/C.
Good luck
Old Jun 30, 2021 | 07:04 PM
tnswt's Avatar
The 4 speed W30 with a 3.42 to 1 rear took a V02, Heavy Duty Radiator with 2.00 inch core; 19" blade with fan clutch; no shroud.
Heavy Duty Engine Cooling & Alternator (Y72) was not available with V02. Keep in mind heavy duty cooling can be a confusing concept. In essence, V02 is a level of HD cooling, just as V01 is. Two things to keep in mind during this time period is that there is Heavy Duty Cooling and there is Heavy Duty Radiators. It helps to be specific when using these terms to reduce confusion.
V01 = Heavy Duty Radiator 2.70 inch core,
V02 = Heavy Duty Radiator 2.00 inch core.
Thanks - Mike
Ref: PIM Sec 11/pg 50 and RocketDevo
Hope this helps.
Old Jun 30, 2021 | 07:17 PM
tnswt's Avatar
Good luck
Too, the Feb 1970 parts book shows OR (4949861) clutch used with 4400 OAI, as already pointed out #2.
Old Jul 1, 2021 | 02:59 AM
joesw31's Avatar
I commented on this thread specifically because post number 2 states that the “OR” clutch was not used on 4-speed W-30s. Which is not correct from my experience.
Old Jul 1, 2021 | 06:23 AM
tnswt's Avatar
Joesw31 I agree OR is correct for 4-speed W30, but in post #2 it was also stated the OR clutch was used on 442 OAI. It was my attempt to be fair.
Moreover, this topic has been well rehearsed on this site.
See: https://classicoldsmobile.com/forums...70-w30-132725/
Old Jul 1, 2021 | 07:27 AM
joesw31's Avatar
Fan clutch application has been thoroughly hashed on this site for many years.
Old Jul 1, 2021 | 11:24 AM
Stefano's Avatar
Thanks - Mike
I have a 4 speed W-30 original 3.42 gear car with the three Core radiator, no shroud and clutch fan.
Old Jul 2, 2021 | 07:40 PM
11971four4two's Avatar
MOTORHEAD
HEY
can you please read the stamp on the front of the fan clutch
Thank YOU
Have a great 4 July Independence day week end
jpc647
Dec 16, 2016 06:21 AM
70convert
Mar 26, 2016 11:00 AM
Bernhard
Nov 20, 2015 12:56 PM
cdoering
Jul 28, 2014 12:24 PM
rmoths
Apr 17, 2013 10:02 PM
