Distributor gear clearance?
Old May 21, 2021 | 07:58 AM
Olds 65's Avatar
Hello could someone clarify if the distributor gear need to rest on the boss below while the engine is running to maintain correct positioning of the two gears or can the distributor gear float above pulling down on the distributor, there has been some wear on my engine block as in some of the other threads by other members so there is clearance (not riding on the block ) .Thank you in advance.
442craig
Jul 24, 2019 11:41 PM
big man
Apr 1, 2018 08:40 AM
BillK
Feb 12, 2018 05:36 PM
1970Olds442
Nov 24, 2017 07:15 AM
foo
Jun 26, 2017 06:25 PM
