What is it? 71 4-4-2....
Old Apr 27, 2020 | 08:55 PM
vCode442's Avatar
Vincit qui se vincit
OK looks to be on top of the starter, 455, orient yourself with the motor mount and the driver side W manifold. There is a stud with nut with washer loosely attached. Partially obscured by motor mount attachment point.
What is it? Missing something? No prizes just your satisfaction for sharing knowledge, car runs and drives great.
Thanks and hope everyone is staying safe, please no ingesting or injecting disinfectants.
My guess from the CSM is that it is this stud with a loose bolt. Should it be tightened? Thanks
Old Apr 27, 2020 | 11:41 PM
stellar's Avatar
stellar
Not a problem. It is a starter bolt holding the starter together and it has a threaded extension used for a support brace. Some cars use it and some don't.
Old Apr 28, 2020 | 04:48 AM
Yep, I think you're right.
Old Apr 28, 2020 | 05:31 AM
If you are talking about the second nut and lock washer on that stud that holds the starter together, someone added that - likely the rebuilder that the starter came from. It is not factory. I've never had an Olds with anything attached to that stud.
Old Apr 28, 2020 | 07:19 AM
vCode442's Avatar
Thank you for the replies, so it may have been used on some cars but that’s not certain, I’m curious what it may have been used for - and if so on what cars.
Thanks again!
Old Apr 28, 2020 | 12:37 PM
Yellowstatue's Avatar
That stud is likely a Chebby thing cuz they use a brace that supports the end of the starter. An Olds starter would just have a hex head, no stud.
2blu442
Dec 21, 2018 05:18 AM
sand442man
Apr 9, 2017 10:24 PM
Tom442
Feb 10, 2014 12:47 PM
1969w3155
Sep 1, 2011 01:11 PM
roro1
Nov 26, 2010 05:26 AM
