Steering box upgraded, rag joint ground missing now no horn
Old Mar 31, 2020 | 05:55 AM
vCode442's Avatar
Vincit qui se vincit
I recently upgraded to the quicker ratio steering box and new rag joint - it feels and drives great, however little did I know the rag joint has a ground strap for the horn - apparently the shop didn’t know either.
Is there a way to retrofit one? Whats the answer to get my horn going again - it worked prior to the new box install, I’m betting it’s the lack of a rag joint ground, thanks for any advice.
Old Mar 31, 2020 | 06:12 AM
Here's a universal ground strap. You can probably find them in different lengths:
Amazon Amazon
To test your horn use alligator clips and run 12V and Ground to it from the battery. If this works you know your horn is missing ground. You could also use your multimeter and test for continuity between the negative battery post and the black wire going to the horn.
Old Mar 31, 2020 | 06:25 AM
I had to do this with the new rag joint for my 67. A short piece of wire and two ring fittings. Took longer to write this than to cobble that up.
Old Mar 31, 2020 | 06:59 AM
vCode442's Avatar
Thanks guys. I wasn’t sure it could be that easy of a fix, ground straps are ground straps
Old Mar 31, 2020 | 07:03 AM
Just be sure that you position it so you are electrically connecting the steering shaft flange to the box flange.
Old Mar 31, 2020 | 07:13 AM
vCode442's Avatar
Will do, thank you Joe.
Old Apr 1, 2020 | 10:05 AM
Don R.'s Avatar
Easy fix.
Old Apr 1, 2020 | 10:09 AM
vCode442's Avatar
That’s beautiful, thanks Don.
Toocool
Feb 27, 2018 06:20 AM
71cutlass350
May 20, 2017 06:54 AM
justintiime
Sep 22, 2014 06:26 AM
olds67
Dec 29, 2012 02:41 PM
wmlewis
Apr 11, 2012 04:17 PM
