I am building a 350 rocket from 1977 and NEED HELP
Old October 25th, 2019, 06:07 PM
Mikedeneen21's Avatar
I have no clue what goes here and i’ve asked everybody and no body can tell me what this is
Mikedeneen21 is offline
Old October 25th, 2019, 06:20 PM
The tube for the hot air choke. It make a loop inside the exhaust crossover in the manifold. One end of the tube goes to a fitting on the back of the carb, the other end threads onto the choke housing.
matt69olds is offline
Old October 25th, 2019, 06:34 PM
What do i need to buy that bolts in there ?
Old October 25th, 2019, 06:59 PM
The choke heater tube.
There may be multiple vendors who sell these; this is just the one that popped up on a web search.
https://www.ebay.com/itm/70-71-72-86...-/160904313091
You'll also need the two tubes that connect the heater tube to the choke thermostatic housing and to the air inlet on the top rear of the carb.
Fun71 is offline
Old October 25th, 2019, 07:02 PM
What year is the manifold?
oldcutlass is online now
Old October 25th, 2019, 07:08 PM
what year is the manifold?
1977
Old October 25th, 2019, 07:10 PM
This will provide you w/ the basic idea of the choke heater tube:
Vintage Chief is online now
Old October 26th, 2019, 06:21 AM
BSiegPaint's Avatar
BSiegPaint is offline
Old October 26th, 2019, 06:44 AM
Originally Posted by BSiegPaint
where did you buy yours from ?
Old October 27th, 2019, 10:03 AM
BSiegPaint's Avatar
Inline Tube on one of their eBay auctions. Search "Oldsmobile choke stove" and you'll find them.
Old October 27th, 2019, 01:08 PM
oddball's Avatar
Note that passage is open to the exhaust. You need a gasket between the manifold and the plate that bolts onto it. The looped tube goes down into the manifold.
I ended up making gaskets using the stiffest gasket material from the gasket kit @ Autozon. Use Copper RTV. It can be tough to find just that gasket on its own, and the cheap flimsy ones can blow apart.
oddball is offline
Old October 27th, 2019, 02:50 PM
FEL-PRO 72586
You should be able to get it from just about any auto parts store for around $3. Heck, even Amazon lists it.
Fun71 is offline
tricordati
July 12th, 2019 01:08 PM
ScottM47448
December 10th, 2012 10:32 AM
Margie's68
August 29th, 2007 02:28 PM
perksolds
August 24th, 2006 07:34 PM
Poetry Rod
February 22nd, 2006 08:05 AM
Quick Reply: I am building a 350 rocket from 1977 and NEED HELP
