I am building a 350 rocket from 1977 and NEED HELP
The tube for the hot air choke. It make a loop inside the exhaust crossover in the manifold. One end of the tube goes to a fitting on the back of the carb, the other end threads onto the choke housing.
The choke heater tube.
There may be multiple vendors who sell these; this is just the one that popped up on a web search.
https://www.ebay.com/itm/70-71-72-86...-/160904313091
You'll also need the two tubes that connect the heater tube to the choke thermostatic housing and to the air inlet on the top rear of the carb.
Note that passage is open to the exhaust. You need a gasket between the manifold and the plate that bolts onto it. The looped tube goes down into the manifold.
I ended up making gaskets using the stiffest gasket material from the gasket kit @ Autozon. Use Copper RTV. It can be tough to find just that gasket on its own, and the cheap flimsy ones can blow apart.
