Bleeding the convertible hydraulic lines
Old February 15th, 2019, 07:06 AM
mmitton's Avatar
I'm going to replace the hydraulic lines in my 70 Supreme convertible. Any suggestions on the best way to bleed the lines?
mmitton is offline
Old February 15th, 2019, 07:44 AM
Tedd Thompson's Avatar
I just run the top up and down a few times and the air seems to get back in the tank. I think our systems are similar though 15 years apart in age..... Tedd
Tedd Thompson is offline
Old February 15th, 2019, 09:33 AM
cjsdad's Avatar
The convertible top hydraulic system recirculates the fluid, like your power steering pump. The lines are small enough that the fluid will be fully circulated by running the top up and down several times. Like Tedd says, make sure it is full and cycle the top a few times. No need to bleed it like your brakes.
cjsdad is offline
Old February 15th, 2019, 02:38 PM
mmitton's Avatar
Thanks for the tips gentleman. I should be good to go. I replaced one side several years ago with copper tubing instead of plastic and it's worked fine so I plan to do the same for the other side.
mmitton is offline
Rocketbrian
June 27th, 2017 04:11 PM
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
leroycjr
Body work
March 28th, 2015 04:20 PM
kens69olds
August 24th, 2014 03:51 PM
Classy 71
July 17th, 2013 08:03 PM
Quick Reply: Bleeding the convertible hydraulic lines
