Bleeding the convertible hydraulic lines
Old Feb 15, 2019 | 07:06 AM
mmitton's Avatar
I'm going to replace the hydraulic lines in my 70 Supreme convertible. Any suggestions on the best way to bleed the lines?
Old Feb 15, 2019 | 07:44 AM
Tedd Thompson's Avatar
I just run the top up and down a few times and the air seems to get back in the tank. I think our systems are similar though 15 years apart in age..... Tedd
Old Feb 15, 2019 | 09:33 AM
cjsdad's Avatar
The convertible top hydraulic system recirculates the fluid, like your power steering pump. The lines are small enough that the fluid will be fully circulated by running the top up and down several times. Like Tedd says, make sure it is full and cycle the top a few times. No need to bleed it like your brakes.
Old Feb 15, 2019 | 02:38 PM
mmitton's Avatar
Thanks for the tips gentleman. I should be good to go. I replaced one side several years ago with copper tubing instead of plastic and it's worked fine so I plan to do the same for the other side.
Rocketbrian
Jun 27, 2017 04:11 PM
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
leroycjr
Body work
Mar 28, 2015 04:20 PM
kens69olds
Aug 24, 2014 03:51 PM
Classy 71
Jul 17, 2013 08:03 PM
