Quarter window roller spring
Old Apr 1, 2018 | 09:10 PM
Zr1bandit's Avatar
Can anyone explain how the spring goes on the 1970 442 rear quarter window roller ? Can it be installed without removing the window ?? Thanks --Greg
Old Apr 2, 2018 | 08:35 AM
mrolds69's Avatar
I can't explain it, but it definitely can go on and off easily w/o removing the window or track. I think you can access it through the door jamb vent and moving the window down. I'll look for a pic.
Old Apr 2, 2018 | 09:11 AM
Zr1bandit's Avatar
Great---a pic will help----hope this will take out the slop in the widow when its half rolled down. It rocks front to back as of now when in the the half down position.
Old Apr 2, 2018 | 09:49 AM
mrolds69's Avatar
This is Camaro, but the same...I'm still looking for a better pic.
http://image.superchevy.com/f/797460...rter-glass.jpg
Old Apr 7, 2018 | 10:24 AM
Zr1bandit's Avatar
quarter window spring
Help can anybody tell me how to install the spring on the rear quarter window roller on a 1970 442--- maybe some pics on how it goes in thanks---Greg
Old Apr 7, 2018 | 01:45 PM
mrolds69's Avatar
How about this pic? This is Chevelle...the spring can only go on 2 ways. The coil goes around the hook like in the pic. One end goes against the tab to hold it. The other end goes in the "v" of the roller to hold pressure on the roller. The spring in this pic needs to be flipped to go on the roller like you see in the pic.
https://www.johnsclassiccars.com/par...Chevelle/16558 Any good for you?
Old Apr 7, 2018 | 02:49 PM
Zr1bandit's Avatar
Thanks-----i think i got it. Window still has a little play in it tho from front to back when half rolled down------
slade69
May 26, 2021 06:25 AM
johnnyjaws
Feb 23, 2015 04:30 PM
Longhorncutlass
Mar 2, 2009 01:53 PM
Redog
Aug 14, 2008 06:56 PM
