How do you adhere the quarter window gasket and chrome to the quarter window 72 conve
Old Sep 9, 2017 | 04:47 PM
72442455's Avatar
Joe Ralph
the driver side quarter window trim and gasket is loose on quarter window - I just redid the seals and it looks like some kinda two sided foam/putty sticky stuff was in there - 72 convertible - anyone know what that is? Or what I should use? - thanks Joe
Old Sep 9, 2017 | 08:10 PM
stevengerard's Avatar
they originally came with what seemed like a mixture of jute and black sealant. I'd like to know the best way to do it as well. I am assuming some kind of silicone adhesive but not sure which one would be best.
Old Sep 9, 2017 | 09:05 PM
When I installed the ones on my car back in the early 90s I used strips of 3M 130C rubber self-fusing tape that we used at work for high voltage applications and it has held up very well over the years. I've read since that there is a proper tape that glass companies use for this type of work.
Old Sep 10, 2017 | 06:29 AM
jozw30's Avatar
Use the 3m weatherstrip adhesive.
Old Sep 10, 2017 | 06:40 AM
RandyS's Avatar
^^This - visit your local glass shop and get some 'glass tape'. It is a rubber strip a couple inches wide and you cut it to length. It comes in several different thicknesses, you might start out with the thinest one. Cut a strip of it the length of the chrome piece and either lay it in the channel or wrap it around the glass. You can trim the excess with a razor knife after it dries. The chrome piece will be pretty stubborn when reinstalling it. When I did mine, the glass guy suggested using a light oil, like sewing machine oil on the rubber before attempting to put it back together - you will want to wear latex gloves - it's really messy.
Old Sep 10, 2017 | 02:28 PM
bccan's Avatar
They used to (generically?) call that "Tough Pack" or "Tuff Pak", not sure if it is sold anymore. Glass guys I have discussed it with over the last few years all said they just urethane them on.
Old Sep 11, 2017 | 08:33 PM
steverw's Avatar
Google door glass setting tape, it comes in several different sizes.
Old Sep 14, 2017 | 06:47 PM
Rocketowner's Avatar
J&J Auto Fabrics has it on their Site. Larry
Old Sep 14, 2017 | 07:31 PM
^ http://www.jjautofabrics.com/glass-setting-tape/
Old Sep 15, 2017 | 06:50 PM
BackInTheGame's Avatar
I got mine from rubber the right way, through their ebay store. Works like a champ. There is a thread on CO about installing using some soapy water. Fantastic! Once the water evaporates it is almost as if the metal is welded to the glass. A 10' x 1.5 inch strip cost about $15 IIRC, and I've got about 7.5 feet left.
Oldssupreme
Jul 27, 2016 03:56 AM
malibru
Oct 10, 2015 01:10 PM
jensenracing77
Mar 2, 2014 08:55 AM
CutlassLegend
Aug 13, 2011 07:37 PM
dallasite21
Jun 20, 2010 05:37 AM
