Gas tank painting or coating
Old Feb 19, 2018 | 06:54 PM
jensenracing77's Avatar
There are no new gas tanks available for the 61-63 Cutlass and Jetfire. I am wondering how to get that original zinc plating look. If I paint it I don't want to use the traditional metallic paint because I think that looks worse than anything else that I could do. If I can't get the original look I am thinking I will just paint it a gray color.
Anyone have any options for this?
Old Feb 19, 2018 | 07:04 PM
I wonder how well it would look if it were cleaned to bare metal and clear coated?
Old Feb 19, 2018 | 09:04 PM
ELY442's Avatar
I use the gas tank zinc paint from Eastwood
Old Feb 20, 2018 | 04:37 AM
Do you have a picture of how it turned out? I thought that looked like Stainless steal metallic paint.
Old Feb 20, 2018 | 05:25 AM
Get it galvanized?
Old Feb 20, 2018 | 05:28 AM
Regardless of what you do for the outside make sure you coat the inside as well:
https://www.summitracing.com/parts/sum-900056-3
Here's the paint Ely mentioned:
https://www.eastwood.com/ew-tank-ton...sol-13-oz.html
FWIW, when I coated the inside of the gas tank on my 71 98 I used the restoration kit from Eastwood. I painted the exterior with RustOleum and it looks great.
Old Feb 20, 2018 | 06:43 AM
Get it galvanized?
From what I am looking into, nobody can do a tank. I want that original look but the metallic paint just don't get there. I may try to clean and clear one to see how that looks. I think it is going to be the closest.
Olds64, I will likely have to if I can't find a better tank. This one looks nearly spotless inside but it does have a pin hole from the outside on the seam. Now that I have used different style of lines I like the POR liner the best. I don't use much of there product but the tank liner is great. I have not used the Eastwood stuff but I bet it is close to the same as POR.
Old Feb 20, 2018 | 06:49 AM
POR makes excellent products. I used their high temperature paint on my engine. It's great.
joemo
Sep 21, 2022 04:47 AM
dbenton
Paint
Jul 13, 2016 11:54 AM
1carsick
Oct 17, 2012 09:10 AM
oldzy
Paint
Feb 9, 2012 01:57 PM
Texas442
Jan 30, 2012 05:36 PM
