Should I use a battery warmer or trickle charger?
It's suddenly damn cold here in Long Island. My cars kept in the garage and I try to drive it at least once a week even through the winter, or if nothing else at least let it run for 15 or so minutes weekly. But it does get tougher to start the colder it is, and I'm concerned if I miss a week or two it won't start at all. I didn't have any issues last winter, but concerned for this one for some reason. I still plan to drive the car as much as possible, as long as there's no wet stuff.
There are so many factors that determine ease of starting; one certainly is the speed at which the starter motor turns the engine. If you feel that the speed is suffering from some weakness in the battery, by all means, do whatever you can to provide aid. A heater and a trickle charger may make a difference. Neither should do any harm except to your wallet.
I got a small charger / maintainer from Lowes for just under $20 and liked it so much I got a second for another vehicle and bought one for a relative.
https://www.lowes.com/pd/Schumacher-...ainer/50256403
Just remember that just because there isn't any snow on the ground at that moment doesn't mean winter roads can't do damage. Once they salt the roads that stays there until we get a good dousing of rain to wash it away.
Why it can be challenging to start these cars in our neck of the woods this time of season, it should be no different than last year. A battery tender is a great tool and highly recommended, but make sure your battery has not reached it's limit. I remember years back you could buy a 5 year/60 month battery, now I find it challenging to find a 4 year/ 48 month unit that actually lasts that long. Tight and proper size cables from the battery to the negative and starter are important as well. You are right to be concerned as a weak battery will cause a lower voltage which will burn up a starter in no time.
I use a battery disconnect and recommend it to anyone. I have a K Mart warranty battery, Duralast, I think, running 13 years now. I have an Autozone battery of same time that also is still ok, but it is actually disconnected, like remove cable, except when ran, too.
I would highly recommend a battery tender. I've been using one for years. A neg cutoff switch is a good suggestion too. The good thing about these old cars is they don't have a lot of electronics that draw on the battery.
I would also recommend a AGM battery if you need a new one. These don't have the dreaded leaking issue of the traditional wet/flooded batteries. No more rotted out core support under the battery
Pepboy's is running a special on Bosch AGM batteries now, 25% off. Sadly batteries are not cheap any more...
https://www.pepboys.com/search/?term=bosch+agm
Battery tender/maintainer, as others have properly advised, is good insurance against a dead battery.
Also, as has been stated, is battery now on its last leg due to old age? If so, nothing will overcome that circumstance.
You can get a battery tender for under $10 at Harbor Freight. I have several in use during the winter months: 442, sport bike, and lawn tractor. I've been using these same devices for several years now, and my equipment never fails to start.
Thanks for all the good advice all! After a few days of bitter cold I went out and she started right up. The battery's less than a year old but was completely discharged and recharged once. I also once used a portable charger to jump the battery and the charger blew right up due to the long crank time, so Im just looking to be extra cautious... Appreciate the info!
I've had great luck using Deltran Battery Tenders, they are a float charger so you can leave them connected all winter if need be. I got tired of having to buy a new lawnmower battery every year so I tried the battery tender Jr. That worked so well I bought the larger one for my summer car.
Tedd Thompson
February 21st, 2015 08:43 AM
carid
December 4th, 2014 02:55 AM
