Body Data Plate
Old Mar 16, 2017 | 01:34 PM
72blue442's Avatar
Body Data Plate
My 72 442 has a Fisher Body Data plate located on the left cowl,above the firewall, the number is ST72 34267LAN494888, this does not match the
VIN # on the title, is the VIN located anywhere else on the car??
Old Mar 16, 2017 | 02:05 PM
stevengerard's Avatar
on the top of dashboard left of the steering wheel near the window. Look at it from outside through the window. It will not match the cowl tag
Old Mar 16, 2017 | 02:36 PM
Look at the base of the windshield on the driver's side.
The cowl tag was installed by Fisher Body before the VIN was even assigned to the car, so they won't match. The year, body style code, and assembly plant must be the same as those on the VIN, however. The first four characters of your VIN must start out 3J67... for a Cutlass Supreme convertible (all Cutlass convertibles were Supremes in 1972, even with the 442 option). The fifth character will be the original engine, followed by a 2M in positions six and seven for 1972 and Lansing. The final six are just the sequential serial number of the VIN and are unrelated to the cowl tag.
Old Mar 16, 2017 | 02:42 PM
72blue442's Avatar
Thanks much guys, geesh, I knew most of that, I got to cut down on the coffee!!
x2248344
Aug 10, 2012 04:18 AM
iuhoops83
Aug 8, 2008 05:27 AM
rida142
Sep 3, 2007 02:33 AM
4Forty2
Jul 11, 2007 04:55 AM
ndiver63
Sep 11, 2006 04:10 PM
