OEM part number
Old Mar 15, 2017 | 06:55 AM
Zr1bandit's Avatar
OEM part number
Looking for the OEM part number for the front coil spring for a 1970 442 W-30 with AC. Trying to order new front coils and want to get the right ones. Thanks. Greg
Old Mar 15, 2017 | 08:32 AM
stevengerard's Avatar
I'll do some digging for what I bought. I will tell you when you look at what the spring companies say non make sense. That is, the manifold saves 40 lbs yet the AC adds weight (can't remember how much). Thus it specifies different springs for a W30 than a 442 but doesn't differentiate between AC and non AC or at least it didn't. Yet the 442 springs did. I also went with a front spring 1 inch shorter and back .5 inch shorter
Old Mar 15, 2017 | 08:43 AM
OEM part number is 400997 with A/C, 400333 without.
Old Mar 15, 2017 | 12:26 PM
Let me add that Moog claims that their P/N 5450 replaces both 400333 and 400997 (as well as others), so don't expect to find an exact replacement unless you stumble over an NOS set of OEM parts.
Old Mar 15, 2017 | 12:36 PM
Zr1bandit's Avatar
Joe, i thought the assembly manual showed the part number for spring with AC as 400335-------?? For A body1970 442
Old Mar 15, 2017 | 12:52 PM
I got that from the factory parts book, though it's possible that 400997 superceded the earlier number. This is the Jan 1972 printing.
Old Mar 15, 2017 | 02:16 PM
Zr1bandit's Avatar
That's interesting cause the assembly manual i have shows it to be 400335 looks like ??
Old Mar 15, 2017 | 02:18 PM
Zr1bandit's Avatar
Old Mar 15, 2017 | 02:23 PM
Keep in mind that the Assy Manual and the Parts Book are both snapshots in time. The drawings in the Assy Manual got updated over the course of the production run, and these updates may or may not be captured in the reprint that you have. Same thing with the Parts Book. Part numbers were regularly superceded and there is even a separate part number supercession booklet that documents this. Olds part numbers were pretty much assigned chronologically, so the higher 400997 would be more recent than 400335. I suspect that 400997 is the 1971-72 spring part number and superceded the 1970 vintage 400335. Note that 400335 is more consistent with the other 1970 spring numbers (400333 and 400334). I can't say what the difference might be, but apparently Olds didn't think it mattered enough to keep the original number. If anyone has the Dec 1969 printing of the Parts Book, it would be interesting to see what it shows.
Of course, you still have the problem that the available replacement springs cover just about all of those part numbers interchangeably.
Old Mar 15, 2017 | 02:30 PM
Zr1bandit's Avatar
Yes. I see what your saying----maybe just keep old springs, was going to add a 1/2" shim anyway to get a little more height out of them. Did this 25 years ago and it worked nice, gave the car a good stance ------
Old Mar 15, 2017 | 02:39 PM
Ancient Iron's Avatar
1970 Olds w/ air cond. 4467-87 pt # 400335 conv.- hardtop
4477 pt# 400334 2 dr. sedan
Old Mar 15, 2017 | 02:42 PM
Zr1bandit's Avatar
You must have same manual as i have --------
Old Mar 15, 2017 | 02:45 PM
Is that the Dec 69 printing parts book? If so, then my supercession theory is probably valid. This once again demonstrates the importance of using a parts book that was printed as close to your car's model year as possible.
Old Mar 15, 2017 | 02:48 PM
It's the bible
Old Mar 15, 2017 | 02:50 PM
Actually it is a Feb '70 printing
Old Mar 15, 2017 | 02:52 PM
Well, it gets more murky. These two pages are also from the 1972 printing. 400335 is shown as being used on 1971 Supreme convertibles "with 442 suspension" and no A/C, and also on all 1971 A-body 2dr cars WITH A/C and w/442 suspension.
these are the ones I bought for the hard top W30
http://www.rockauto.com/en/moreinfo....=1213489&jsn=8
Well one of them the numbers have changed they were moog 501
the ones for the convertible I bought straight from moog, can't find their info yet.
Old Mar 15, 2017 | 02:55 PM
Well, it gets more murky. These two pages are also from the 1972 printing. 400335 is shown as being used on 1971 Supreme convertibles "with 442 suspension" and no A/C, and also on all 1971 A-body 2dr cars WITH A/C.
Doesn't that make sense since the convertible is heavier and a hardtop with AC would weigh about the same as a convertible without AC. But then the W30 lowers weight a bit.
Old Mar 15, 2017 | 03:01 PM
The parts book doesn't differentiate W-30 vs less 442s, only A/C vs. non-A/C.
Old Mar 15, 2017 | 03:53 PM
Zr1bandit's Avatar
Anybody got the specs for the OEM spring to compare to what is available ??
Old Mar 15, 2017 | 04:38 PM
Call these people for OEM springs https://www.eatondetroitspring.com/
Old Mar 15, 2017 | 04:49 PM
Zr1bandit's Avatar
Just fired off request for a quote on new front coil springs---thanks again
Old Mar 15, 2017 | 04:50 PM
jensenracing77's Avatar
This is correct for A/C. Here is a picture of the original spring from my W-30 with A/C and still had the tag on it.
Old Mar 15, 2017 | 04:53 PM
Zr1bandit's Avatar
Wow. That sure answers the question then------thanks
Old Mar 15, 2017 | 04:54 PM
Cool, Please let us know what their reply is. I need a round for my '69
Old Mar 15, 2017 | 04:57 PM
Zr1bandit's Avatar
Will do--------
Old Mar 16, 2017 | 06:27 AM
So definitely a superceded part number. Interesting. Thanks for the info.
Old Mar 16, 2017 | 07:26 AM
ROCKET VAPOR's Avatar
Lance
Provide Eaton Detroit Spring with the specs from the AMA spec sheets, and they will make you the identical spring.
https://www.gmheritagecenter.com/doc...2_Info_Kit.pdf
Old Mar 16, 2017 | 06:32 PM
Zr1bandit's Avatar
Quoted me 169.00 plus approx. 33.00 shipping -----------
Old Mar 16, 2017 | 08:36 PM
seems like a lot. I swear I paid under 100 for a pair or eatons and even less than that for Mooogs
Octania
Mar 7, 2016 03:43 PM
Trailrunner
Jan 5, 2014 05:24 AM
Alg
Jan 1, 2013 05:04 PM
deweirdt
Jul 21, 2009 08:29 AM
