70-442 heat is intermittent
Old October 27th, 2016, 03:20 PM
safray's Avatar
(The site won't let me post this under "Interior/Trim", so didn't know where else to put it). I recently removed/cleaned/replaced all under-dash HVAC parts in my car that had been sitting for years. When I slide my heater control to "heat", I get full heat coming from vents or heater or defrost when at idle, but it won't stay hot when driving at highway speeds. I'm thinking the door is not staying in the correct position. Is it possible that air is coming in & blowing the door open at highway speeds? It seems to do it equally at all blower motor speeds. I first thought vacuum leak but isn't the door mechanically controlled? I'd like some opinions on what to look for before I start removing the under dash parts. Thanks!
safray is offline
Old October 27th, 2016, 04:07 PM
svnt442's Avatar
Check the vacuum lines at the ball under the hood. It sounds like you may have a leak somewhere.
svnt442 is offline
Old October 27th, 2016, 04:08 PM
svnt442's Avatar
And no, it's all vacuum operated with diaphragms to operate the doors.
svnt442 is offline
Old October 28th, 2016, 05:25 AM
safray's Avatar
thanks Randy - I'll go chasing vacuum lines this weekend & tear into it if needed.
safray is offline
Old October 28th, 2016, 05:58 AM
svnt442's Avatar
OK, I was thinking of the later vacuum controls. These are partially cable operated.
svnt442 is offline
Old October 28th, 2016, 06:14 AM
bw1339's Avatar
Vac to heater valve?
bw1339 is offline
Old October 28th, 2016, 06:18 AM
svnt442's Avatar
OK...lol....that set is for non-AC heater controls.
Here is the AC stuff...
svnt442 is offline
Old October 28th, 2016, 06:20 AM
safray's Avatar
That's what I was thinking (your pictures are better than my service manual pictures!). I think I'll check the vacuum lines I can get to easily first, then go after that cable adjustment & all other vacuum hoses.
safray is offline
Old October 28th, 2016, 06:36 AM
First, I ASSUME you have A/C, since you didn't say. Second, if the system works at high vacuum at idle but not when the throttle is opened (and vacuum drops) then you obviously have a problem with the vacuum storage ball and/or the check valve that retains vacuum in it. You might also have a leak somewhere that's small enough to allow the system to work at high vacuum conditions but not at medium.
Most likely the problem is the vacuum operated heater control valve. this is a normally closed valve that opens with vacuum. If vacuum is inadequate to hold it open, flow of hot water to the heater core is blocked.
joe_padavano is offline
Old October 28th, 2016, 07:33 AM
svnt442's Avatar
These are from my service manual and I took the pics with my phone.
svnt442 is offline
Old October 28th, 2016, 07:34 AM
safray's Avatar
thanks Joe - yes, it's an AC car & you're describing the problem exactly.
safray is offline
Old October 28th, 2016, 07:56 AM
My442's Avatar
This>
My442 is offline
coldfire
June 29th, 2013 07:39 PM
lsutigers93
August 17th, 2012 06:39 PM
68442Convertible
July 5th, 2012 10:25 AM
Rocketbrian
March 23rd, 2012 08:54 PM
henryk8398
Ninety-Eight
January 16th, 2011 04:27 PM
Quick Reply: 70-442 heat is intermittent
