Fuel line routing to carb - 63 F-85
Old May 21, 2016 | 08:17 AM
70-442-W30's Avatar
344879M363895
I have to say, I'm concerned where this fuel line was previously, basically resting up behind the distributor and coil, touching the engine. I'm wondering is this the correct way to have this routed? Sure it makes the line nice and neat and almost hidden, but I'm wondering about it being so close to the heat. This is using a rubber Gates line.
Thoughts?
Old May 21, 2016 | 11:34 AM
pogo69's Avatar
morgan
IT'S not thru the frame and up around the fuel pump?
Old May 21, 2016 | 11:54 AM
The line from the pump to the carb was metal from the factory, not rubber.
Old May 21, 2016 | 01:55 PM
70-442-W30's Avatar
344879M363895
Here is what I have, I replaced the line but used the same hose and path that was there before:
Old May 23, 2016 | 09:25 AM
70-442-W30's Avatar
344879M363895
No comments on the pic. I assume that
1.) It is OK as is.
Or 2.) You all want to see me go in up a big ball of flames.
Old May 23, 2016 | 09:38 AM
nonhog's Avatar
Registered car nut
As much as I hate to comment on a fuel hose post.
I say make a hard line for it. Hose is only appropriate for flex areas.
OEM is done that way and NHRA will boot you for hose over a certain length.
If you don't have benders and flare tools maybe someone near you does?
Old May 23, 2016 | 09:57 AM
70-442-W30's Avatar
344879M363895
Does anyone have a pic of one of these with a metal line on it so I can see what the path was stock?
Old May 23, 2016 | 11:48 AM
nonhog's Avatar
Registered car nut
Not sure I kept the line? If I have it I can snap pics tonight.
May have more pictures at home?
Old May 23, 2016 | 03:56 PM
64Rocket's Avatar
I can get a pic for you on Wednesday at the earliest. The two engines I have are 4 barrel carbs.
On your case, I would just use alum tube and make it go up high around the dist and into the carb.
Gene
Old May 24, 2016 | 09:26 AM
nonhog's Avatar
Registered car nut
This is a 4 barrel application. Hope it helps!
Old May 25, 2016 | 11:25 AM
70-442-W30's Avatar
344879M363895
Thanks for the help guys.
Old May 25, 2016 | 10:18 PM
Ancient Iron's Avatar
I don't think you have the correct carb. I could swear the fuel inlet faced the front of the motor. I'll look at mine to be sure
1968_Post
May 20, 2016 04:57 PM
rjohnson442
Apr 21, 2015 05:24 PM
frozencaveman
Mar 10, 2011 10:32 PM
dantana
Aug 21, 2009 10:58 AM
RAMBOW
Jun 9, 2009 07:33 PM
