Fuel line routing to carb - 63 F-85
I have to say, I'm concerned where this fuel line was previously, basically resting up behind the distributor and coil, touching the engine. I'm wondering is this the correct way to have this routed? Sure it makes the line nice and neat and almost hidden, but I'm wondering about it being so close to the heat. This is using a rubber Gates line.
Thoughts?
Thoughts?
As much as I hate to comment on a fuel hose post.
I say make a hard line for it. Hose is only appropriate for flex areas.
OEM is done that way and NHRA will boot you for hose over a certain length.
If you don't have benders and flare tools maybe someone near you does?
I can get a pic for you on Wednesday at the earliest. The two engines I have are 4 barrel carbs.
On your case, I would just use alum tube and make it go up high around the dist and into the carb.
Gene
Gene
1968_Post
May 20, 2016 04:57 PM
frozencaveman
Mar 10, 2011 10:32 PM
