fuel line - stock pump to Quick Fuel Slayer carb
I need to figure out a fuel line from the fuel pump to a Quick Fuel dual inlet carb. What complicates matters is I've installed Vintage air and the compressor bracket is close to the outlet fitting on the pump. I'm not sure I have room for a AN fitting unles I can find a 45 or 90 degree fitting to go in the pump. I'm sure I'm not the 1st to run into this... any suggestions? I could get a stock line and cut it, then install the AN's further upstream. Is that the best option?
I'd been on Russel's site forever trying to come up with what I needed... I just found a swivel 90 degree AN-6 to 5/8-18 thread that looks like it may work. The remaining question is whether there's room to the a.c compressor bracket to get it in.
Knowing exactly how to refer to the fitting so as to limit the search was the biggest problem. Once I got the terminology correct, things got easier.
cut123
September 20th, 2013 05:47 PM
