Quick fuel slayer 600 carb on Eddie 3711
Old May 9, 2015 | 04:57 PM
wcourt3010's Avatar
Hi, does anyone know if a quick fuel slayer carb will fit on an edelbrock performer 3711 erg intake with or without an adapter? Was looking at one on youtube and I believe the throttle linkage will hit the egr plate similar to an edelbrock performer carb.
Old May 9, 2015 | 05:21 PM
It should accept the Quickfuel with no adapter if your not running an EGR.
http://www.edelbrock.com/automotive/.../2000/2711.pdf
Old May 9, 2015 | 05:26 PM
wcourt3010's Avatar
No I have installed the egr block off plate. This is related to my strong exhaust post, my Rochester is running too rich. If that can't be sorted I want to know my carb options. Thanks.
Old May 12, 2015 | 02:57 PM
70vert's Avatar
If you want to use a carb other than the stock q jet you will need to use a spacer to get the linkage to clear the egr hump on the intake.
Eddie Hansen
Jan 8, 2024 05:35 PM
dancutlass
Jan 2, 2014 12:54 PM
cut123
Sep 20, 2013 05:47 PM
rookieoldsguy72
Aug 26, 2013 06:43 AM
GAOldsman
Jun 2, 2012 06:52 AM
