Z bar pivot bracket
Z bar pivot bracket
I'm using a 455 Fa block and it does not have the pivot point for the Zbar
There was a bracket to fix that problem. I have not been able to find one.
Anyone any know of such an item and maybe where to find one.
Gene
Gene
Fleming , yes the crank is drilled. The block I’m using does NOT have to pivot point for the Z bar. There is no way to drill it.
I know there is a bracket that was made to fix this problem, that is what I’m looking for.
Gene
Gene
I didn't realize they completely eliminated the flat. Some bean counter saved 3 cents on each one.
Like Joe said, you can always go hydraulic. It's a lot easier these days than it was 20 years ago when I did mine. McLeod has a sweet one that bolts in place of the bearing support. I just got one after getting tired of the leaky, circle track ones.
cfair
Suspension & Handling
July 3rd, 2022 10:40 AM
